ipo: error #11035: Fatal error cannot open library
Carmen_S_
in order to change a LS-DYNA material subroutine, I installed Microsoft Visual Studio 2008 and the Fortran compiler 10.1. When I want to execute the nmake file via the fortran command window, I get the following error messages:
ipo: error #11035: Fatal error cannot open LIBCMT
ifort: error #10014: problem during multi-file optimization compilation <code1>
NMAKE: fatal error U1077: 'ifort' : return code '0x1'
I am a new Fortran user and do not know what they mean, so I googled it. But the answers were mostly vague, like "try to change the environment variables for xy" and I really don't want to make the situation even worse.
Thank you very much for your answers!
Best,
Carmen
pbkenned1
Everything works normally with VS2008 + ifort-10.1 + your solution (Console6_1.zip) on my system.  The solution was already set for the x64 Debug configuration, and the only change I made was to change "Configuration Properties->Linker->General->Output File" to <inherit from project defaults>.
I was able to build and run in the VS debugger (see the attached)
I don't see how the problem could have anything to do with the solution file.  I can only assume the problem has something to do with you system.
Just a WIG -- where ever you are attempting to write the executable file -- are you certain you have the necessary permissions to write to that directory?  You might test by opening a command prompt, cd'ing there, and creating a test file with notepad or some other editor.
Patrick
