issue with assumed length + assumed shape character array declaration
Thomas_C_
It is unclear to me why the following declaration is causing a run-time error when compiled in ifort. This source does run as expected without error when compiled using GNU GCC version 4.4.3:
subroutine splitString(stringArray, stringCSV, separator)
        implicit none
        character(len=*), dimension(:), intent(inout) :: stringArray
        character(len=*), intent(in) :: stringCSV
        character(len=*), intent(in), optional :: separator
end subroutine
The run-time error is:
forrtl: severe (408): fort: (6): Non-unit stride for dimension 1 of assumed-shape array STRINGARRAY in routine SPLITSTRING and fe_asha_1ds1 specified
my ifort compiler is:
Intel(R) Visual Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 12.0.4.196 Build 20110427
Roland_W_Intel1
We really can't tell what's going on here either.  If you can provide a reproducer, submit an issue to Intel Premier Support and we'll investigate.
Steven_L_Intel1
Please also provide the compile options used. The error message suggests you are using an undocumented option that has major restrictions.
Thomas_C_
Steve, Roland.
Thank you for your help - while this error was consistently reproducible on the date that I reported it, I've not been able to reproduce it since. It must have been a device issue that a reboot solved.
