have been working on a statistical program for the last 18 months using IVF integration with Visual Studio Community. I've compiled with 2015 then 2016 and now 2017. But with 2017 I get all my fonts reduced. Fontsize = 24 displays as 8 and others reduced proportionally. Everything was AOK until I installed 2017 and wow!
A small piece of my code is:
hDC = GetDC(NULL)
if (hDC == NULL) Then
mas = 16
hDC = GetDC(NULL)
End If
sxWidth = GetDeviceCaps(hDC, HORZRES)
syHeight = GetDeviceCaps(hDC, VERTRES)
sColorDepth = GetDeviceCaps(hdc, BITSPIXEL) * &
GetDeviceCaps(hdc, PLANES)
iret = ReleaseDC(NULL,hDC)
if (sxWidth < 1024) Then
mas = 12
DOT1 = 1
DOT2 = 1
DOT3 = 2
elseif (sxWidth < 1600) Then
mas = 14
DOT1 = 1
DOT2 = 2
DOT3 = 2
else
mas = 16
DOT1 = 1
DOT2 = 2
DOT3 = 3
end if
bret = GetClientRect(ghDlg, rectd)
bret = GetClientRect(ghWndMain, rectp)
rectd%bottom = rectp%bottom
rectp%left = DIALOGWIDTH + 1
rectd%right = DIALOGWIDTH
gMaxx = rectp%right - rectp%left
gMaxy = rectp%bottom - 1
bret = SetWindowPos(ghDlg, int(NULL,HANDLE), 0, 0, DIALOGWIDTH, DIALOGHEIGHT, 0)
bret = DlgSetInt(gDlg, IDC_MYSPIN, 0, DLG_POSITION)
ghBrushWhite = CreateSolidBrush (RGB(248,248,255))
ghBrushBlack = GetStockObject(BLACK_BRUSH)
ghPen = GetStockObject(BLACK_PEN)
hBlackPen = ghPen
ghBrush = ghBrushWhite
lp%fErase = 0
lp%rcPaint = rectp
! Fill-in the log paint structure
lf%lfWidth = 0
lf%lfEscapement = 0
lf%lfOrientation = 0
lf%lfWeight = FW_BOLD
lf%lfItalic = FALSE
lf%lfUnderline = FALSE
lf%lfStrikeOut = FALSE
lf%lfCharSet = ANSI_CHARSET
lf%lfOutPrecision = OUT_DEFAULT_PRECIS
lf%lfClipPrecision = CLIP_DEFAULT_PRECIS
lf%lfQuality = DEFAULT_QUALITY
lf%lfPitchandFamily = ior(DEFAULT_PITCH, FF_DONTCARE)
lf%lfFaceName = "Courier New"C
If (hMyFont12 == NULL) Then
lf%lfHeight = mas
hMyFont12 = CreateFontIndirect ( lf )
lf%lfHeight = mas + 2
hMyFont16 = CreateFontIndirect ( lf )
lf%lfHeight = mas + 4
hMyFont20 = CreateFontIndirect ( lf )
lf%lfHeight = mas + 8
hMyFont24 = CreateFontIndirect ( lf )
lf%lfHeight = mas + 16
hMyFont36 = CreateFontIndirect ( lf )
end if
Any suggestions would be greatly appreciated/
Brooks
The background color setting function has been renamed in IVF (carried over from MS Fortran) to avoid a conflict.
rval = MSFWIN$SetBkColor (hdc, yellow)
Also, the background/foreground color is simply an attribute of the DC for text output, it is not the same thing as selecting a brush which uses/creates an allocated resource and hence must be destroyed/deallocated/restored when that code section completes; so the color value is not a handle to anything and the extra calls to "restore" the "oldbkcolor" and so forth are not needed.
There are a number of WinAPIs which have been similarly renamed; do a search on MSFWIN$ over the IVF project include paths.
Hi, Brooks
The GetDC, GetDeviceCaps are all Windows APIs. Besides upgrade intel Fortran to 2017, have you also upgraded Visual Studio Community or your Windows operating system?
Hi, Brooks
In addition, did you try debug build? Will you see the same issue with optimization disabled?
Have you tried messing around with SetProcessDpiAwareness to see whether that might be the problem?
Firstly it seems strange that changing compiler level would cause this problem. Do you still have the older compilers in VS? Options > intel compilers > fortran - or something like that - can be used to select an older compiler for back to back testing.
The font selections is a windows best guess to match the attributes you have selected, changes in windows/windows environment could effect that.
I have no magic insight into this problem, I would be tempted after selecting the font object from the handle to call
GetTextMetrics for the working and non-working version just to verify exactly what is happening.
This is a Windows issue, only accidentally related to IVF. I don't think you should rely on all the elements of your logfont structure remaining constant over multiple calls/returns to CreateFontIndirect(). I have put similar code in a subroutine which can be called multiple times for multiple fonts...
! Creates a font with simple characteristics. The face name and size
! are provided, along with bold and italic flags. Returns a handle
! to the new font, or 0 on failiure.
INTEGER(HANDLE) FUNCTION CreateSimpleFont (faceName, size, bold, italic)
IMPLICIT NONE
CHARACTER(LEN=*), INTENT(IN) :: faceName
INTEGER, INTENT(IN) :: size
LOGICAL, INTENT(IN) :: bold
LOGICAL, INTENT(IN) :: italic
TYPE(T_LOGFONT) :: logfont
INTEGER(HANDLE) :: hfont
logfont%lfHeight = size
logfont%lfWidth = 0
logfont%lfEscapement = 0
logfont%lfOrientation = 0
IF (bold) THEN
logfont%lfWeight = FW_BOLD
ELSE
logfont%lfWeight = FW_NORMAL
END IF
logfont%lfItalic = italic
logfont%lfUnderline = .FALSE.
logfont%lfStrikeout = .FALSE.
logfont%lfCharSet = ANSI_CHARSET
logfont%lfOutPrecision = OUT_DEFAULT_PRECIS
logfont%lfClipPrecision = CLIP_DEFAULT_PRECIS
logfont%lfQuality = DEFAULT_QUALITY
logfont%lfPitchAndFamily = IOR(DEFAULT_PITCH, FF_DONTCARE)
logfont%lfFaceName = faceName
hfont = CreateFontIndirect (logfont)
CreateSimpleFont = hfont
END FUNCTION CreateSimpleFont
Hi Paul,
I'll try it but what 'use' statements do I need?
Brooks
You can use the module IFWIN
Robert
The F90 interface to CreateFontIndirect() is in GDI32.f90, which is included in IFWIN.f90. You will also need IFWINTY.f90 for Windows defines such as HANDLE, T_LOGFONT, FW_* and so forth. Siince your existing code already references those items, no changes may be required, just put the subroutine in the same module as your calling code.
OK, got it to work but the textout function is now printing my font with a white background. I added SetBkColor and it compiles OK but I get a error LNK2019: unresolved external symbol _setbkcolor referenced in function MMYHEADEROUT_mp_MYHEADEROUT in the link process. What must I do to the project options to resolve this error. I am running a pure x64 compile/link setup.
Here is my revised code modified from above
!DEC$ ATTRIBUTES STDCALL, ALIAS : 'CreateSimpleFont' :: CreateSimpleFont
use IFWIN
Integer(Handle):: CreateSimpleFont
INTEGER(4), INTENT(IN) :: size
LOGICAL(4), INTENT(IN) :: bold
LOGICAL(4), INTENT(IN) :: italic
logfont%lfWidth = 0
IF (bold) THEN
ELSE
END IF
return
and I invoke it with
hMyFont12 = CreateSimpleFont( "Courier New"C, mas, .TRUE., .FALSE.)
mas = mas + 2
hMyFont16 = CreateSimpleFont( "Courier New"C, mas, .TRUE., .FALSE.)
mas = mas + 4
hMyFont20 = CreateSimpleFont( "Courier New"C, mas, .TRUE., .FALSE.)
mas = mas + 8
hMyFont24 = CreateSimpleFont( "Courier New"C, mas, .TRUE., .FALSE.)
mas = mas + 10
hMyFont36 = CreateSimpleFont( "Courier New"C, mas, .TRUE., .FALSE.)
end if
The code using the font is
use ifwin
use gdi32
use user32
use ifqwin
use kernel32
use PearsonGlobals
Integer(4):: x, y, lnth, lenx
Integer(BOOL):: bret
Integer(4):: oldBkColor
Integer(4):: BlueBkColor
Character(100):: myBuffer
Type (T_TEXTMETRIC) ta
if ((hmyFont36 == NULL) .or. ($Maxi == FALSE)) Then
return
End if
if (ghwDC /= NULL) Then
bret = EndPaint(NULL, lps)
End If
ghwDC = GetDC(NULL)
if (ghwDC == NULL) Then
return
End If
hOldPen = SelectObject(ghwDC, GetStockObject(BLACK_PEN))
BlueBkColor = RGB(0,0,255)
oldBkColor = SetBkColor(BlueBkColor)
hOldFont = SelectObject(ghwDC, hMyFont24)
myBuffer = 'Pearson Distribution Curves (PDC)'
myBuffer = TRIM(AdjustL(myBuffer))
bret = GetTextMetrics(ghwDC, ta)
Call GetLength(myBuffer,lnth)
lenx = ta%tmAveCharWidth * lnth / 2
x = GetDeviceCaps(ghwDC, HORZRES) / 2 - lenx
y = 0
bret = textOut(ghwDC, x, y, myBuffer, lnth)
rectg%top = 0
rectg%bottom = 80
rectg%left = 700
rectg%right = 1200
bret = ValidateRect(NULL, rectg)
hOldFont = SelectObject(ghwDC, hOldFont)
hOldPen = SelectObject(ghwDC, hOldPen)
oldBkColor = SetBKColor (oldBkColor)
x = ReleaseDC(NULL, ghwDC)
ghwDC = NULL
return
Using this code I am actually writing in the system area, which on my Win10 maxhine is a blue band.
Brooks
There is a function setbkcolor in IFQWIN and and SDK function of the same name in GDI32 that has a different interface (it takes 2 parameters) I think that is the one you are after.
At a glance I don't see any need for USE IFQWIN in that routine. Also you don't need GDI32, USER32 or KERNEL32 as they are all included in IFWIN.
Thanks Andrew and Paul.
Brooks
