library problem
tf81
Hi,When I link the library file got from my friend,get the following error message. "./eos.a(eos.o)(text+0x2f0f)::In function 'eos_':undefined reference to 'f_iof' ". There is 'f_iob','f_ioc','f_iod',and 'f_stop'. other than 'f_iof'.Why get this message? It is because my fortran compiler vergion differ with my friend?
In order to link a Fortran library you get from someone else, you need to have the libraries from that compiler on your system. If one is version 7 and one is version 8, then the library needs to be recompiled with the version you have (or the earlier version should update.)
tf81
Is recompiling the library to get source file(*.f),to compile the file,and to make a new library?MustI get the source file ?
Yes, you would need the source files to recompile.
tf81
Thank you for the information.
