29417 Discussions
license is only good for 30 Days after installing fullIntel Visual Fortran V11.0 Professional ?? HElp!
mwrinch
Last week I downloaded the TRIAL license for fortran V11. I then uninstalled it and PURCHASED the full professional version of Intel Visual Fortran V11.0 Professional. After installing it, when I run the command line compiler, it tells me that the license is only good for 30 Days. How can I get rid of this and make sure my full professional license is installed?
Mike.
DavidWhite
Valued Contributor II
Quoting - mwrinch
Mike.
The License files are stored in
C:Program FilesCommon FilesIntelLicenses
Check that you only have the new license file there, not the trial license. Rename the trial license *.oldlic or similar.
David
What happens is that the compiler found the trial license first, and reports the expiration. Once that license expires, it will skip it and use your regular license. Removing the trial license file is fine if you want the message to go away.
mwrinch
OK thanks. I guess I have to wait 28 days now to see.
Mike.
Or you can delete the trial license.
