linking with gcc
Joan_D_
I am trying to compile a mex file using ifort 10.1.012 and apparently I need a library such as libgcc.a, which does not seem to come with the distribution. Is there a way to get this library or its equivalent for ifort?
Jo
TimP
libgcc.a comes with gcc. You would not be able to run ifort without an installation of g++, and that installation would be broken without libgcc.a.
gcc -print-search-dirs should show you where the gcc libraries are.
