Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
macOS 11 Big Sur not supported with PSXE 2020 and older Intel Compilers
Intel(R) Parallel Studio XE 2020 for macOS*  and all prior versions of Intel(R) Parallel Studio XE for macOS* are NOT compatible with macOS* 11 Big Sur.
Errors will be missing libraries such as -lSystem not found
More background:
New in macOS Big Sur 11.0.1, the system ships with a built-in dynamic linker cache of all system-provided libraries. As part of this change, copies of dynamic libraries are no longer present on the filesystem. Code that attempts to check for dynamic library presence by looking for a file at a path or enumerating a directory will fail.
https://developer.apple.com/documentation/macos-release-notes/macos-big-sur-11_0_1-release-notes
