minor issue on module declaration
christensen__asbjorn
Dear experts,
I noticed this minor issue on module declaration in relation to ifort version 17.0.2 (I'll soon upgrade to version 19, so I don't know, if the problem is fixed in the head version). The following declaration is accepted:
module test2
  integer, parameter :: namelen = 999  ! string buffer length
  type derived_type
     character(len=namelen) :: fname
  end type derived_type
end module
whereas the following declaration is rejected
module test3
  type derived_type
end module
... with the error message :
test3.f90(5): error #6406: Conflicting attributes or multiple declaration of name.   [NAMELEN]
test3.f90(3): error #6219: This variable, used in a specification expression, must be a dummy argument, a COMMON block object, or an object accessible through host or use association.   [NAMELEN]
compilation aborted for test3.f90 (code 1)
... as far as I can read the Fortran standard, no requirement exist on the order of statements in the module specification section.
Best wishes, Asbjørn
Juergen_R_R
Valued Contributor II
Hi Asbjørn,
indeed, I can also not spot (in a quick glance on the module part of the standard) anything that would enforce an ordering, however, it is rather natural and makes life a lot easier for the front-end parser I suppose. All compilers that I can get my hands on (gfortran, ifort, PGI, NAG) flag your first example as an error.
Cheers,
    Jürgen
Steve_Lionel
There absolutely is an ordering in the standard! (emphasis mine):
A variable in a specification expression shall have its type and type parameters, if any, specified by a previous declaration in the same scoping unit, by the implicit typing rules in effect for the scoping unit, or by host or use association. If a variable in a specification expression is typed by the implicit typing rules, its appearance in any subsequent type declaration statement shall confirm the implied type and type parameters. (F2018 10.1.11p6 (Specification expression)
This has nothing to do with modules - it's a restriction on declaration ordering that has been in the standard "forever".
Williams__Ben
Hi Asbjørn,
       From a draft version of the 2003 standard at https://wg5-fortran.org/N1601-N1650/N1601.pdf page 14 Table 2.1 it does state that parameter statements must come before derived type statements. Presumably I'm not misreading that!
Ben
Edit: looks like Steve beat me by a minute.
Steve_Lionel
There isn't an ordering of the statements themselves. But in looking closer, the wording I quoted doesn't seem to apply, since it says "variables". In the context here, namelen is required to be a constant expression, which it is, but I'm not yet finding wording that requires a previous declaration of a named constant (PARAMETER). Still looking...
Williams__Ben
Are you looking for this?
Page 83 Section 5.1.2.10 of https://wg5-fortran.org/N1601-N1650/N1601.pdf
A named constant shall not be referenced unless it has been defined previously in the same statement, defined in a prior statement, or made accessible by use or host association
Apologies for not using the 2018 standard I do not have access- pretty sure this requirement has always been true.
Edit: Section 8.5.13 in 2018 draft from http://fortranwiki.org/fortran/show/Fortran+2018
Steve_Lionel
Yep - that will do it! The one place I didn't look! Thanks!
