mpiifort: Command not found
Jasmeet_S_
I am facing this problem with mpiifort:
make mpi=openmpi MPIdir=/home/singh/src all -f Makefile
mkdir -p ./bin
mkdir -p ./lib
make[1]: Entering directory `/home/singh/ukrmol-out/source/libouter'
mpiifort -i8 -w -p -openmp -i8 -O0  -c borncros.f
make[1]: mpiifort: Command not found
make[1]: *** [borncros.o] Error 127
make[1]: Leaving directory `/home/singh/ukrmol-out/source/libouter'
make: *** [SUBDIRS] Error 2
TimP
If you have installed both Intel Fortran and Intel mpi, you source both the compilervars and mpivars scripts:
(e. g. under bash)
source ......./bin/compilervars.sh intel64
source .,.../bin64/mpivars.sh
If your system is managed professionally you may have module commands set up.
TimP
(e. g. under bash)
Jasmeet_S_
Thanks Tim. Now mpiifort is working.
I am trying to compile source codes and created .optrpt but executable output file is not created. The following remark I got during MAKEFILE run:
ifort: remark #10397: optimization reports are generated in *.optrpt files in the output location
and please find the attached MAKEFILE and outer
Jasmeet_S_
Please find the .optrpt for your understanding.
Please advice me on this problem.
Yurkiv__Vitaliy
which bin64? There are several in different directories, for example,
~/intel/compilers_and_libraries_2017/linux/mpi/bin64
~/intel/impi/2017.4.259/bin64
EduardoEnr_S_Intel
rm -f gtcmpi module.o main.o function.o setup.o ran_num_gen.o set_random_values.o load.o restart.o diagnosis.o snapshot.o chargei.o poisson.o smooth.o field.o pushi.o shifti.o fft_gl.o chargee.o pushe.o shifte.o tracking.o Lorentz_coll.o collision.o *.mod
make: Circular module.o <- module.o dependency dropped.
mpiifort  -O3 -xHost -qopenmp -c module.F90
make: mpiifort: Command not found
make: *** [module.o] Error 127
cp: cannot stat
Hello everyone, i have  a question regarding the same issue as well mpiifort command not found ,  the error that i already pasted at the top of this question it's the one that's appears on my platform... just in case i'm using architecture 64 on my platform and also i have the same question, i don't know which folder will be the correct one to use on the ./env01 file, by the way in using for compiler Intel® Parallel Studio XE Composer Edition for Fortran and C++ Linux*  and the Intel® MPI Library for Linux*....
If any body knows about this i really appreciated if someone it's able to tell me something ...
Best regards...
Juergen_R_R
Valued Contributor II
Eduardo, did you look at comment #2 by Tim P. on sourcing the compilervars?
