29285 Discussions
multiple preprocessor defines on one file IFC 8
tonyjay68
when preprocessing a file , ie. test1.fpp :
In CVF6.6 to have twoMacros/symbols defined on one file they are separated by a comma in the IDE. i.e.
SYMBOL1,SYMBOL2
The 'context balloon help' tells you this !
This does not work in IFC8 in visual studio.net (it reports an error with @MACROS
The CVF project is converted to SYMBOL1,SYMBOL2
So
1. I don't know how to do it in the new environment
2. the project converter should have converted this to a new format as well (In my opinion)
3. Is there context help in.net for IFC. I do not seem to have any fortran help files at all. May be it is because I downloaded the product.
Does anyone have a workaround ?
Tony
Tony,
You're right, the project converter missed this change. The new way is to separate the symbols witha semicolon. You can also use the "..." list button to create a list.
The context-sensitive help displays at the bottom of the properties box without your needing to press anything. But I admit that here it is deficient. I'll pass along this problem to the developers.
