named enum, bind(c)
Jeffrey_H_Intel
Both http://fortranwiki.org/fortran/show/Typed+enumerators and http://docs.cray.com/books/S-3693-36/html-S-3693-36/z1018297010.html show an example of a named enum in Fortran with ISO_C_BINDING.
I cannot build this with Intel 17 or GCC 6.2.  Can you please help me understand what I am doing wrong?
! enum.F
      module enumtest
      use iso_c_binding
#if NAMED_ENUM
      enum, bind(c) :: color
        enumerator :: red = 4, blue = 9
        enumerator yellow
      end enum
#else
      enum, bind(c)
        enumerator yellow
      end enum
#endif
      end module enumtest
$ ifort -std08 -free -g -warn all -traceback -c enum.F
$ ifort -std08 -free -g -warn all -traceback -DNAMED_ENUM -c enum.F
enum.F(4): error #5082: Syntax error, found '::' when expecting one of: <END-OF-STATEMENT> ;
enum.F(5): error #6163: This statement is not in the correct order.
enum.F(6): error #6163: This statement is not in the correct order.
        enumerator yellow
enum.F(7): error #8131: An END ENUM statement occurred without a corresponding ENUM statement.
      end enum
compilation aborted for enum.F (code 1)
$ gfortran-6 -std=f2008 -c enum.F
$ gfortran-6 -std=f2008 -DNAMED_ENUM -c enum.F
enum.F:4:6:
      1
Error: Unclassifiable statement at (1)
enum.F:5:22:
                      1
Error: ENUM definition statement expected before (1)
enum.F:6:18:
         enumerator yellow
                  1
enum.F:7:9:
       end enum
         1
Error: Expecting END MODULE statement at (1)
IanH
Named enumerations are not part of standard Fortran (2008 or 2015 draft).  That wiki page is just a suggestion for future language revisions.
IanH
FortranFan
@Jeff,
Fyi, another thread at comp.lang.fortran - https://groups.google.com/forum/#!msg/comp.lang.fortran/iWUgXY0UJ4s/BlGjDBhlEgAJ;context-place=forum/comp.lang.fortran
jimdempseyatthecove
Scoped enumerators would be nice, though I do not see a distinction between:
ENUM_TYPE::ENUM_PARAMETER_VAL
and
ENUM_TYPE%ENUM_PARAMETER_VAL
If you wish to remove the scoping, then you could use module scoped parameters
SUBROUTINE ...
  USE COLORS
or
SUBROUTINE...
  BLOCK
    USE COLORS
    CALL FOO(Red, Green, Blue)
  END BLOCK
or
SUBROUTINE...
  USE COLORS, RED=>colorRED, ...
Jim Dempsey
At the risk of sounding like a broken record - er - a corrupted MP3? - ISO_C_BINDING has nothing whatsoever to do with ENUM, BIND(C) or BIND(C) in general, other than the module and the BIND attribute are both part of C interoperability. Though they have some letters in common, they are not the same thing.
jimdempseyatthecove
By the way, your command line for ifort did not include the -fpp option. I am surprised the compiler did not complain about the fpp #'s too.
Jim Dempsey
The .F (capital F) file type causes fpp to be run implicitly on Linux and MacOS. Similar for .F90 (vs .f90)
Jeffrey_H_Intel
Sorry, Steve, I keep using ISO_C_BINDING as incorrect shorthand for "all the C interoperability stuff in Fortran 2003."  I will try to be better about that.
Jeffrey_H_Intel
Jim Dempsey
I use .F rather than -fpp because other Fortran compilers support the former.
On Mac is that the filesystem is case-insensitive, so one can get into truly horrible situations when trying to rename files from .f to .F and vice versa, so I default to .F since it is obnoxious to change it later, especially when Git is involved.
jimdempseyatthecove
Bad habit (assumption) learned from my earlier Fortran (FORTRAN) programming in Windows.
Jim Dempsey
mecej4
With some Windows compilers, even if the file is named xyz.f in the directory listing, referring to it as xyz.F in the compiler command line causes the preprocessor to be run. This can be convenient, but it can also be troublesome!
