It looks as if we moved that topic to Using Intel® Visual Fortran to Create and Build Windows*-Based Applications
Excellent! It looks like pages 18-24 of that document are what I need.
Thanks bunches,
Brian
Does the actual argument list in the call contain expressions with subscripted variables? Does the list contain items that are intended to specify bounds on other arguments?
With the scanty information that you provide, not much can be said about what is wrong with your program. In fact, it is possible to write any number of error-free programs that satisfy every aspect of your description. Therefore, and as is often the case, the devil is in the details and if you don't show us the code, either in its entirety or at least the important portions of it, I doubt that we can help you.
