29652 Discussions
openmp array reduction segmentation fault
camey1
I have been trying to run some fairly straightforward code which uses array reductions, but have been getting segmentation faults when the array is made larger than a certain size.
I have set "ulimit -s 50000000", so stack size should not be a problem, and the code works in gfortran. Is this a known issue, or are there subtleties I am not noticing?
Compiled using ifort 11.1 20090511
[fortran]subroutine sparse(rowcol,dat,vold,vnew,matlength,arraylen)
integer matlength,arraylen
double precision dat(arraylen)
integer rowcol(arraylen,2)
double precision vnew(matlength)
double precision vold(matlength)
vnew = 0.0d0
!$OMP PARALLEL PRIVATE(i) SHARED(vold, rowcol, dat,l) REDUCTION(+:vnew)
!$OMP DO
  do i=1,arraylen,1
    vnew(rowcol(i,1)) = vnew(rowcol(i,1)) + vold(rowcol(i,2))*dat(i)
  end do
!$OMP END DO
!$OMP END PARALLEL
return
end[/fortran]
Any help would be appreciated,
jimdempseyatthecove
Are there any duplicates in
rowcol(i,1) i=1,arraylen?
if not, you can remove the reduction (and make vnew shared)
Jim Dempsey
