29651 Discussions
passing command line argument as parameters
roddur
I have a routine to get 4 command line argument:
module chk_argumnt
CONTAINS
subroutine chk(x,y)
implicit none
integer::ac
real*4::x,y!,v_a,v_b,e_a,e_b
character(4)::cx,cy,atn1,atn2
! ac=command_argument_count()
write(*,*)command_argument_count()
call get_command_argument(1,cx)
call get_command_argument(2,cy)
call get_command_argument(3,atn1)
call get_command_argument(4,atn2)
read(cy,*)y
read(cx,*)x
write(*,*)atn1,cx,atn2,cy
write(*,*)"from module",x,y
end subroutine chk
end module chk_argumnt
now i want to use them in another routine to initialize variable/
parameters:
program main
use chk_argumnt
real*4::tx=x*10,ty=y*10
! real*4,parameter::tx=x*10,ty=y*10
call chk(x,y)
write(*,*) x
write(*,*) y
end program main
but i cannot do that. What my aim is to supply the main four
parameters from commandline. how can i do that?
rreis
Why not just...
print "input comand 1"
read (*,*) cm1
print "input comand 2"
read (*,*) cm2
and so forth?
you can validate the values after...
Izaak_Beekman
New Contributor II
This is a duplicate thread. the active version is here:
http://software.intel.com/en-us/forums/showthread.php?t=64753
