29487 Discussions
passing type variables to subroutine already allocated
diedro
Dear all,
I have created the following TYPE variables:
 TYPE tPARAM
    INTEGER                                  :: ncl
    REAL,  ALLOCATABLE,DIMENSION(:) :: SET
 END TYPE tPARAM
then I allocate the following variables:
 TYPE(tPARAM),                DIMENSION(0:nParam)  :: PAR2HY
and
  DO iParam=0,nParam
     ncl = PARAM(iParam)%ncl
     ALLOCATE(PAR2HY(iParam)%SET(ncl))
  ENDDO
I would like to pass it to a subroutine as:
  SUBROUTINE PRINT_PARAMETRS(fileunit,fname,nParam,PARAM,eff)
  USE VARS_TYPE
  IMPLICIT NONE
  INTEGER,                                   INTENT(IN) :: fileunit
  CHARACTER(100),                            INTENT(IN) :: fname
  INTEGER,                                   INTENT(IN) :: nParam
  TYPE(tPARAM),                              INTENT(IN) :: PARAM
  REAL,                                      INTENT(IN) :: eff
Now the question:
The fact that I have also
where also SET is allocate will give me some problems? If yes, how can I avoid it?
Thank a lot
FortranFan
@diedro,
Given your original post, you shouldn't have a problem but you don't show much and nor is your code snippet a complete reproducer so one can't be sure.  However you are asking a basic question, so a few suggestions:
diedro
Dear FortranFan, Dear all,
if you want, I could send a fortran example code. This could really help me.
What do
I will also look the links that you send me.
jimdempseyatthecove
Your subroutine declarations appear incorrect. You are declaring nParam and PARAM which seem to imply PARAM is to be an array (with nParam things). Yet PARAM is declared as a single "thing" of type tPARAM. Did you intend for your code to read as:
USE VARS_TYPE
IMPLICIT NONE
TYPE(tPARAM),                              INTENT(IN) :: PARAM(nParam)
Jim Dempsey
diedro
Deal all, Dear Jim,
really really thanks. I get it.
I have also to put nParam.
Now, my concerns even more then before are about PARAM it self. Indeed PARAM is a "Type" with allocated arguments:
ALLOCATE(PARAM(iParam)%SET(ncl))
outside the subroutine call.
What do you think?
Thank again,
Diego
