pointer with too many characters
kooka
I used the fortran wizard to generate some COM interfaces to autocad methods. Then the wizard generatea module with interfaces and pointers to that interfaces, the problem is that when i try to compile the output window show me some errors like this:
Error: This symbol has too many characters[IAcadSectionTypeSettings_GetIntersectionBou]
POINTER(IAcadSectionTypeSettings_GetIntersectionBoundaryDivisionLines_PTR,IAcadSectionTypeSettings_GetIntersectionBoundaryDivisionLines)
where IAcadSectionTypeSettings_GetIntersectionBoundaryDivisionLines is a function. What can I do whitout changing the name of the function, because i don't want to make errors and is an Autocad function and i thik I can't change the name.
Tanks!
You're two characters over the 63-character limit for identifiers. The only option is to shorten the name. If you changed _PTR to _P, that would just sneak in under the wire. But this does mean some manual editing.
kooka
thanks steve. I only have a question. If I modify the name will the autocad function work properly?. That's because i didn't put that name, was the Fortran module wizard with the interfaces it find in the autocad to autocad methods.
Yes - as long as you change it everywhere it appears in the module. That name is derived from the interface name but not dependent on it.
kooka
Thanks Steve i could solve my problem. Now I can Connect with Autocad
