Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
private infos included in obj files
Why the IVF compiler includes the full path of source files into generated .obj files ?  This information goes into .exe and .dll  files of delivered products.
Such information is included also in 'release' versions and can be a potential security issue.
Highlighted
What version are you using,
What version are you using, and what command line?
I haven't been able to reproduce this behavior with a 19.0 compiler using default options, and "findstr /i" to look for the name of the file in the resulting object file or executable.
                   --Lorri
Highlighted
Black Belt Retired Employee
Probably an old version that
Probably an old version that supported /Sox.
Steve (aka "Doctor Fortran") - https://stevelionel.com/drfortran
