problem with deferred assignment overloading
Alexis_R_
I believe the code below is "legal". However, ifort (14.0.1 20131008), with default options (i.e. "ifort -c") gives this error:
ifort_reproducer_140226.f90(90): error #6197: An assignment of different structure types is invalid.   [TEST_WAYPOINTS]
        test_points = test_waypoints
ifort_reproducer_140226.f90(91): error #6197: An assignment of different structure types is invalid.   [TEST_WAYPOINT]
        test_point = test_waypoint
compilation aborted for ifort_reproducer_140226.f90 (code 1)
For what it's worth, the NAG and Portland compilers do not have a problem with this code.
Is it indeed legal? If not, what is the correct way to do deferred assignment overloading?
Is there a workaround for ifort?
module coos
    implicit none
    type, abstract :: abstract_point
        real(kind=8)    ::  coo(3)  =   [0.0d0,0.0d0,0.0d0]
        contains
            private
            procedure(ass_abstract),    deferred        ::  my_assignment
            generic, public                             ::  assignment(=) => my_assignment
    end type abstract_point
    abstract interface
        pure elemental subroutine ass_abstract(lhs,rhs)
            import :: abstract_point
            class(abstract_point),   intent(inout)      ::  lhs
            class(abstract_point),   intent(in)         ::  rhs
        end subroutine
    end interface
    type, extends(abstract_point)       ::  point
        contains
            procedure                   ::  my_assignment   => assign_point_to_point
    end type point
    type, extends(abstract_point)       ::  waypoint
        logical                         ::  refine      =   .true.
        real(kind=8)                    ::  path_length =   0.0d0
        contains
            procedure                   ::  my_assignment   =>  assign_point_to_waypoint
    end type
    contains
    pure elemental subroutine assign_point_to_point(lhs,rhs)
        ! arguments
        class(point),           intent(inout)       ::  lhs
        ! start work
        lhs%coo = rhs%coo
    end subroutine assign_point_to_point
    pure elemental subroutine assign_point_to_waypoint(lhs,rhs)
        ! arguments
        class(waypoint),        intent(inout)       ::  lhs
        ! start work
        lhs%coo = rhs%coo
        select type(rhs)
            class is (waypoint)
                call waypoint_assign(lhs,rhs)
        end select
    end subroutine assign_point_to_waypoint
    pure elemental subroutine waypoint_assign(wp_lhs,wp_rhs)
        ! arguments
        type(waypoint), intent(inout)   ::  wp_lhs
        type(waypoint), intent(in)      ::  wp_rhs
        ! start work
        wp_lhs%coo          =   wp_rhs%coo
        wp_lhs%path_length  =   wp_rhs%path_length
        wp_lhs%refine       =   wp_rhs%refine
    end subroutine waypoint_assign
    pure elemental subroutine waypoint_init(self)
        ! arguments
        type(waypoint),                 intent(inout)   ::  self
        ! start work
        self%coo = 0.0d0
        self%refine      =   .true.
        self%path_length =   0.0d0
    end subroutine waypoint_init
    subroutine coos_unit_test_1()
        ! private variables
        type(point),        allocatable ::  test_points(:)
        type(waypoint),     allocatable ::  test_waypoints(:)
        type(point)                     ::  test_point
        type(waypoint)                  ::  test_waypoint
        ! start work
        allocate(test_waypoints(10))
        call waypoint_init(test_waypoints)
        test_waypoints(2)%coo(1) = 12.3
        call waypoint_init(test_waypoint)
        test_waypoint%coo(1) = 12.3
        allocate(test_points(size(test_waypoints)))
    end subroutine coos_unit_test_1
end module coos
Steven_L_Intel1
I think this is the same issue as in http://software.intel.com/forums/topic/488776 ; It is our issue DPD200249796.
Alexis_R_
Thanks - I'll keep an eye out for this issue.
Izaak_Beekman
New Contributor II
Assuming test_point and test_points are of type point and test_waypoint and test_waypoints are of type waypoint then then there is an issue resolving the generic assignment to the specific assignment procedures. One work around suggested by Kevin Davis was to add unused components to each derived type. As a temporary work around, you might try adding a component to your point type.
[fortran]type ,extends(abstract_point) :: point
    private real :: ifort_dpd200249796_workaround = 0.0
  contains
end type [/fortran]
I'd be curious to know the results of this test and to see the contents of ifort_reproducer_140226.f90 if you are able to share them.
Alexis_R_
Thanks Izaak for the comment. The content of ifort_reproducer_140226.f90 was exactly as in my post above.
I have added the component as you suggested, but I am seeing the same behaviour (this is ifort 14.0.1 20131008).
I attach the modified file, which includes your suggestion.
Izaak_Beekman
New Contributor II
I read your OP too quickly and thought you were getting a runtime error not a compile time error. The only thing that looks potentially dubious to me is declaring your procedures as [fortran] pure elemental subroutine [/fortran]. This may very well be legal F2008 (which I know added impure attribute for declaring elemental procedures, but the only place I've looked into this is in Modern Fortran Explained by MR&C, not the standard itself, and I can't find any mention of explicitly declaring an elemental procedure as pure) but I'm not sure about compiler support for adding the pure/impure attribute to elemental subroutines. At any rate, I couldn't find any work around for this bug.
FortranFan
Izaak Beekman wrote:
... The only thing that looks potentially dubious to me is declaring your procedures as
I don't think the PURE ELEMENTAL attribute has anything to do with this.  I use it often and I do have an example of a generic assignment that works well with the underlying procedure being declared as such.
In my case also, I have a concrete type extended from an abstract type and the procedure that implements the assignment is attributed as PURE ELEMENTAL  The only difference here is the OP is extending it one level further.  I don't think there is anything wrong with it; as Steve indicated, this appears to be a compiler bug.
FortranFan
See a modified version of OP's code example below.  This modified code is effectively similar to some code I've used extensively.  It too gives a compiler error at line #143; a similar assignment at line 140 doesn't give an error.  I think this shows some issue within the compiler with defined assignments involving polymorphic objects:
[fortran]
module coos_mod
    implicit none
     contains
        private
        procedure(assign_abstract), pass(lhs), deferred :: my_assignment
    abstract interface
        pure elemental subroutine assign_abstract(lhs, rhs)
            class(*), intent(in)                 :: rhs
        end subroutine
    end interface
end module coos_mod
module point_mod
    use coos_mod, only : abstract_point
    implicit none
    contains
        procedure, pass(lhs) ::  my_assignment => assign_point_to_point
    end type point
contains
    pure elemental subroutine assign_point_to_point(lhs, rhs)
        ! arguments
        ! start work
        select type(rhs)
            type is (integer(kind=4))
               lhs%coo = 0.0d0
            type is (real(kind=8))
               lhs%coo = 0.0d0
            class is (point)
                lhs%coo = 0.0d0
            class default
        end select
end module point_mod
module waypoint_mod
    use point_mod, only : point
    implicit none
    contains
       procedure, pass(lhs) :: my_assignment => assign_point_to_waypoint
    end type
contains
    pure elemental subroutine assign_point_to_waypoint(lhs, rhs)
        ! arguments
        ! start work
        select type(rhs)
               lhs%coo = 0.0d0
               lhs%coo = 0.0d0
            class is (waypoint)
               lhs%coo = 0.0d0
               call waypoint_assign(lhs, rhs)
        end select
        ! arguments
        ! start work
        ! arguments
        ! start work
        self%coo = 0.0d0
end module waypoint_mod
module type_int_mod
   implicit none
   type, public :: myint
      integer :: i
   end type myint
end module type_int_mod
module test_mod
    use waypoint_mod, only : waypoint
    use type_int_mod, only : myint
contains
    subroutine testassign()
        ! private variables
        type(myint) :: t
        test_point = 3         ! <-- This works
        test_waypoint = 0.0d0  ! <-- This works
        t%i = 3
        test_point = t     ! <-- This works
        test_waypoint = t  ! <-- This works
        test_point = test_waypoint ! <-- This doesn't work
    end subroutine testassign
end module test_mod
[/fortran]
FortranFan
For whatever it's worth, the code in the original post as well as the modified one I posted in Quote #8 compile without errors in gfortran, MinGW Build 4.8.1
Izaak_Beekman
New Contributor II
I was neither contradicting Steve's assertion that this is a compiler bug, nor was I claiming that pure elemental was the trigger of this bug. I was merely speculating that it must either be a new F2008 feature or illegal code. (I believe F2008 is when impure elemental was added, and prior to that all elemental subroutines had to be pure, and did not require the pure attribute to be explicitly added.) I have no experience with explicitly declaring elemental procedures as pure (or impure) and tend to avoid new language features which I don't really need because I worry about compiler support.
