problem with forum post form
tropfen
not knowing why, i came accross the following problem:
I am not able to write a post using firefox browser 2.0.0.1 based on linux or win xp. I am not able to fill in the messagebox, its stops saying: script failure. Even stopping the script is not possible.
Do i have to change options of the browser?
Thanks in advance
Frank
Jugoslav_Dujic
Valued Contributor II
Same thing here with Firefox 1.5.0.9. The "Script not responding" bug has always been present, but it seems that today it can't be persuaded to work at all. As a workaround, try IE Tabextension (which I use while composing this).
This is a problem I reported to the forum support folks a while ago, and they're working on it. Like Jugoslav, I use IE Tab for the forums (and set the IE Tab option to always open the ISN forums in IE Tab.)
I was told of another workaround, which seems to work. When you get the error message, click Continue, wait a few seconds, then press Tab. You should then be able to type.
They are working on fixing this.
