In an old code, while compiling correctly with ifort 9 and 10, giving problem with 11.x.
As is the output, we get, for 11.x,
[cpp]Fatal : ALLOC : workspace overflow, need at least********* Fatal : ALLOC : workspace overflow, need at least********* total workspace size = 8000 K total space allocated= 1752 M workspace used: max****** K now****** K arrays defined: max 9 now 9 FEXIT :program aborted [/cpp]but for ifort 9.1.52, i have the correct result:
[cpp]total workspace size = 8000 K total space allocated= 0 M workspace used: max 31 K now 28 K arrays defined: max 19 now 17 FEXIT :LMINIT [/cpp]The full code is large enough to put it here. the corresponding subroutine is:
[cpp] subroutine wkinit(wksize) C- Simple FORTRAN dynamic memory allocation C ---------------------------------------------------------------------- Ci Inputs: Ci wksize:maximum size of workfile Ci leng :lenght of array to allocate (DEF..) Ci jprint:(WKPRNT) Ci lopt :(WKSAV) Ci string:(WKCHK) Co Outputs: Co ipname:offset of the integer array w (DEF.. RLSE) Co lrest :number of words left in common pool (DEFASK) Cr Remarks: Cr Memory is allocated from a single heap. The heap is declared as Cr an integer array in common block W by the main program. Its size Cr is fixed by the size of W as declared by the main program. It Cr is possible to allocated memory from the top of the heap, and to Cr free memory already allocated from the top of the heap. It is Cr not possible to free memory allocated from the middle of the heap. Cr Cr To use these routines, first call WKINIT with NSIZE = size of W. Cr Cr Character, integer, real, double precision, complex or double Cr complex arrays can then be allocated by calling DEFCH, DEFI, Cr DEFR, DEFDR, DEFC or DEFDC with an index IPNAME and LENGTH the Cr desired length. IPNAME is returned as the effective offset of Cr the integer array W. If it is desired that the array be Cr initialized to zero, pass LENGTH as the negative of the desired Cr length. Cr Cr Allocated memory can be freed by calling RLSE(IPNAME) where Cr IPNAME must one of the indices from a previous allocation. All Cr blocks of memory allocated after IPNAME are also released. Cr Cr WKPRNT turns on or off a trace that prints a message each time Cr memory is allocated or released. Also when turned on, Cr runs through links each time RLSE is called. Cr DEFASK returns the amount of memory remaining in the pool Cr WKSAV sets an internal switch so that a heap allocation request Cr returns the negative of length of the request in IPNAME Cr when not enough memory is available, rather than aborting. Cr In this case, no memory is allocated and no other internal Cr parameters are changed. Cr WKINFO prints information about the arrays allocated Cr WKCHK runs through links to see if any array was overwritten Cr call wkchk(string), where string terminated by '$' C ---------------------------------------------------------------------- implicit none C Passed variables: integer ipname,leng,lrest,jprint,wksize logical lopt character*(*) string C Local variables: integer chrpos,i,i1mach,ip0,ipfree,ipmax,iprint,ipx,ipy,irnd,isig, . j,jopt,jpr,length,lunit,ndefd,ndefmx,ndfdmx,ndfsum,nsize parameter(ip0=5,ndefmx=100) character*72 messg1,messg2,messg3,messg4 logical lerr C Common blocks: C --- dynamical memory allocation: integer w(1) common/wkarr/w C Save statement: save ipfree,ipmax,jpr,lerr,ndfdmx,ndfsum,nsize C External calls: external ainit,chrpos,dinit,errmsg,i1mach,iinit,iprint,lunit C Intrinsic functions: intrinsic iabs,isign,max0 C Statement functions: irnd(i) = (i+499)/1000 C --- DEFINE STORAGE SIZE ------ C --- START OF FIRST ARRAY AND MAX NUMBER TO BE DEFINED: ipfree = 5 ipmax = 0 jpr = 0 lerr = .false. ndfdmx = 0 ndfsum = 0 nsize = wksize return entry wkprnt(jprint) C --- Set debug switch for heap management if (jprint.eq.2) then jpr = 1-jpr else jpr = jprint endif write(lunit(1),307)jpr return entry wksav(lopt) lerr = lopt return entry defask(lrest) C---- Return number of words left in common pool lrest = nsize - ipfree - 2 if (jpr .gt. 0) write(lunit(1),306) lrest return C --- SUBROUTINES TO DEFINE ARRAYS OF VARIOUS TYPES entry defi(ipname,leng) C --- Allocate integer array length = leng jopt = 1 goto 10 entry defr(ipname,leng) C --- Allocate single precision real array length = leng*i1mach(17) jopt = 2 goto 10 entry defrr(ipname,leng) entry defdr(ipname,leng) C --- Allocate double precision real array length = leng*i1mach(18) jopt = 3 goto 10 entry defc(ipname,leng) C --- Allocate single precision complex array length = leng*2*i1mach(17) jopt = 4 goto 10 entry defcc(ipname,leng) entry defdc(ipname,leng) C --- Allocate double precision complex array length = leng*2*i1mach(18) jopt = 5 goto 10 entry defl(ipname,leng) C --- Allocate logical array length = leng jopt = 6 goto 10 entry defch(ipname,leng) C --- Allocate character array length = (leng+3)/i1mach(6) jopt = 7 goto 10 10 isig = isign(1,length) length = max0(iabs(-length),1) ndefd = 0 ipy = 0 ipx = ip0 do while (ndefd.lt.ndefmx.and.ipx.ne.ipfree) if (ipx .lt. ip0 .or. ipx .gt. nsize) then write(messg1,400) ndefd,ipx,ipy call errmsg(messg1,4) endif ndefd = ndefd + 1 ipy = ipx - 1 ipx = w(ipy) enddo ipname = ipfree if (lerr .and. ipfree+length+2 .gt. nsize) then ipname = -length if (jpr .gt. 0) write(lunit(2),404)-length return endif ipfree = ipfree + length + 1 ipfree = 4*((ipfree+2)/4)+1 ipmax = max0(ipmax,ipfree) w(ipname-1)=ipfree ndefd = ndefd + 1 ndfdmx = max0(ndfdmx,ndefd) ndfsum = ndfsum + length if (jpr.gt.0) write(lunit(1),301)ndefd,leng,length,ipname,ipfree-1 if (ipfree .gt. nsize) then write(messg2,401) ipfree call errmsg(messg2,4) endif if (isig .ne. 1) then if (jopt.eq.1) call iinit(w(ipname),-leng) if (jopt.eq.2) call ainit(w(ipname),-leng) if (jopt.eq.3) call dinit(w(ipname),-leng) if (jopt.eq.4) call ainit(w(ipname),-2*leng) if (jopt.eq.5) call dinit(w(ipname),-2*leng) if (jopt.eq.6) call linit(w(ipname),-leng) if (jopt.eq.7) call chinit(w(ipname),-leng) endif return entry rlse(ipname) C---- Release data up to pointer if (ipname .gt. nsize) then write(messg3,402) call errmsg(messg3,4) endif if (ipname .lt. 3) then write(messg4,403) call errmsg(messg4,4) endif ndefd = 0 ipy = 0 ipx = ip0 do while (ndefd.lt.ndefmx.and.ipx.ne.ipfree) if (ipx .lt. ip0 .or. ipx .gt. nsize) then write(messg1,400) ndefd,ipx,ipy call errmsg(messg1,4) endif ndefd = ndefd + 1 ipy = ipx - 1 ipx = w(ipy) enddo if (jpr.ne.0) write(lunit(1),308)ipname ipfree = ipname return entry wkinfo() C---- Output workspace information ndefd = 0 ipy = 0 ipx = ip0 if (jpr .gt. 0) write(lunit(1),303) do while (ndefd.lt.ndefmx.and.ipx.ne.ipfree) if (ipx .lt. ip0 .or. ipx .gt. nsize) then write(messg1,400) ndefd,ipx,ipy stop endif ndefd = ndefd + 1 ipy = ipx - 1 ipx = w(ipy) if (jpr.gt.0) write(lunit(1),'(4(i6,5x))')ndefd,ipy,ipx,ipx-ipy enddo write(lunit(1),302) irnd(nsize),irnd(irnd(ndfsum)),irnd(ipmax-1), . irnd(ipfree-1),ndfdmx,ndefd return entry wkchk(string) C --- Run through links to see if any dynamic array was overwritten i=chrpos(string,'$',1,60) write(lunit(1),304)string(1:i-1) ndefd = 0 ipy = 0 ipx = ip0 do while (ndefd.lt.ndefmx.and.ipx.ne.ipfree) if (ipx.lt.ip0 .or. ipx.gt.nsize) then write(messg1,400) ndefd,ipx,ipy call errmsg(messg1,4) endif ndefd = ndefd + 1 ipy = ipx - 1 ipx = w(ipy) enddo write(lunit(1),305) ndefd,ipfree-1 return 300 format( ' WKINIT: size=',i5,'K'/) 301 format( ' define array',i4,': leng=',i7,' length=',i7,',',i8, . ' to',i8) 302 format(/' total workspace size =',i6,' K', . /' total space allocated=',i6,' M', . /' workspace used: max',i6,' K now',i6,' K', . /' arrays defined: max',i8, ' now',i6) 303 format(/' array',6x,'begin',7x,'end',7x,'length') 304 format( ' WKCHK : ',60a1) 305 format( ' WKCHK : LINKS OK NDEFD=',i3,' SPACE USED=',i7) 306 format(/' DEFASK: SPACE LEFT',i8,' SINGLE WORDS') 307 format(/' WKPRNT: JPR=',i2) 308 format( ' RLSE : released from: ',i7) 400 format(' ALLOC : link destroyed at start of array',i3,', ptr=', . i8,' at',i8,'$') 401 format(' ALLOC : workspace overflow, need at least',i9,'$') 402 format(' RLSE : release pointer exceeds limit.$') 403 format(' RLSE : release pointer less than 3.$') 404 format(' ALLOC : heap storage exceeded; returning -LENGTH=', . i8,'$') end [/cpp]can you plz comment on this?
Since no one is replying, is this a bug or what?
Quoting - roddur
When you have found the point of divergence, and then investigated to see if perhaps you have a coding error, post again.
It looks like you are getting a huge number somewhere. It may have nothing to do with the routine you posted. You need to check the sizes passed to this routine, and if the function I1MACH is giving the right size values. I would also cautios of accidentally getting 32-bit and 64-bit numbers mixed somewhere. Is the ifort 11.1 version getting compiled on a 64-bit machine? If you are compiling with -i8 to get 64-bit default integers, those MAX0() specific functions might be a problem. Try changed then to the generic MAX().
Quoting - Steve Lionel (Intel)
What investigation have you done? Have you run this in the debugger to see where things start to diverge? You have provided only part of the application, so others can't even try it for themselves.
I know this shortcoming of my post, but this is a std. package and used to run well under ifort11.0. by the way, i compiled it with
ifort -g -c -O2 -w
and the got the result:
$ gdb ../lminit.run
GNU gdb (GDB) Fedora (6.8.50.20090302-33.fc11)
Copyright (C) 2009 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "i586-redhat-linux-gnu".
For bug reporting instructions, please see:
(gdb) run
Starting program: /home/rudra/Recursion/lmto-try/LMTO_A/lminit.run
warning: .dynamic section for "/lib/libc.so.6" is not at the expected address
warning: difference appears to be caused by prelink, adjusting expectations
Space group: Im-3m No.:229
Crystal system: cubic
Generators: I R4X R3D
CTRLUC: PLAT ALAT= 5.98099
-0.50000 0.50000 0.50000
0.50000 -0.50000 0.50000
0.50000 0.50000 -0.50000
total space allocated= 1750 M
Program exited normally.
Missing separate debuginfos, use: debuginfo-install glibc-2.10.1-2.i686 libgcc-4.4.0-4.i586
(gdb)
plz tell me how to proceed.
Sorry, but just because the program worked before, that doesn't mean it is error-free. You need to run the program under control of the debugger and determine at which point something goes wrong. We can't tell you what to do based on output from a partial program. It should be easy enough to step through the code that comes up with the values displayed and see where they come from.
Since you are using ENTRY, be very sure that you do not reference dummy arguments that were not in the list for the entry point through which you entered.
