pulling a flexlm licenses
mckaybc
Does intel visual fortran pull a flexlm licenses when the program is first started or when the program is already running and you invoke the compiler to compile your code?
Thsnks, Brian
No. Only a compile gets a license.
TimP
Quoting - mckaybc
Running the .exe you built doesn't pull a license. When you start the compiler, it must access a license. It holds the license for a few minutes so as not to incur a delay when you compile again.
mckaybc
Quoting - mckaybc
Thsnks, Brian
I am still not clear on the answer. Let me try it this way, If I start up the Visual Fortran programming enviromentand write 5 lines of code and have not compiled anything. Has a flex licenses been pulled?
