There seem to be several limitations.
1. If you have a workspace with multiple projects, for example DLLs, you only see the symbols in the "Active" project.
2. If the same symbol is defined in more than one place (for example as local variables in more than one subroutine), you always get the same definition (rather than the correct definition). For example if "x" is defined in both subroutine A and subroutine B, and you right-click on a usage of xin subroutine B, and then you click to go to the definition of x, you may wind up at the definition of x in subroutine A.
3. Doesn't work for symbols defined in include files.
Two questions:
Q1. Is there a way around these limitations in CVF?
Q2. Is IVF better in any of these regards?
This is Developer Studio's "Source Browser" feature. It does have some limitations, as you found.
Unfortunately, due to MS licensing restrictions, this feature is not available in IVF.
Steve,
I'm using IVF 9.1 in Visual Studio .NET 2003 (as provided with Visual C++.NET).
The "Go to definition" still does not work with 9.1.
Does IVF10 restore that capability, now that you seem on better licensing terms with Microsoft?
I am not very excited about updating IVF mid-project, but could be convinced if the "Go to definition" is available.
Thanks and God bless!
Jack
In Visual Studio 2005, the pop-up menu (right click on variables) does not even provide an option to "go to declaration" or "go to definition". Anybody has a clue about this?
