29071 Discussions
"internal error" with "PARAMETER" attribute
Baschti
I got some code from a colleague, which compiled with other Fortran Compilers, but with Intel I get an "internal error". I boiled it down to a minimal example:
PROGRAM test
REAL, PARAMETER :: a(4) = (/1.0, 2.0, 3.0, 4.0/)
! This gives the internal error
!REAL, PARAMETER :: b(4) = a / SUM(a)
!The following workaround is ok
REAL, PARAMETER :: a_sum = SUM(a)
REAL, PARAMETER :: b(4) = a / a_sum
WRITE(*,*) b
END PROGRAM
#> ifort --version
ifort (IFORT) 2021.7.1 20221019
Copyright (C) 1985-2022 Intel Corporation. All rights reserved.
Error:
#> ifort test.f90
test.f90(4): internal error: Please visit 'http://www.intel.com/software/products/support' for assistance.
[ Aborting due to internal error. ]
with workaround:
#> ifort test.f90
#> ./a.out
0.1000000 0.2000000 0.3000000 0.4000000
Kind regards,
Bastian
Baschti
addition: Error message from ifx
#> ifx test.f90
test.f90(5): internal error: Please visit 'http://www.intel.com/software/products/support' for assistance.
test.f90(5): catastrophic error: Internal Compiler Error: Ref module: ffe_ccvt.c
compilation aborted for test.f90 (code 1)
TobiasK
@Baschti
thanks for reporting this. Unfortunately, it's still failing with our internal development build. I will escalate it to our developers.
TobiasK
@Baschti
we implemented a fix for this issue which will be part of the 2025.2 release
