29341 Discussions
relocation truncated to fit: R_X86_64_32S against symbol
zakeyash
Dear all ;
I have envisaged with the following error :
utput.o: In function `output_':
output.f:(.text+0x439): relocation truncated to fit: R_X86_64_32S against symbol `tmploc_' defined in COMMON section in output.o
output.f:(.text+0x441): relocation truncated to fit: R_X86_64_32S against symbol `tmploc_' defined in COMMON section in output.o
output.f:(.text+0x449): relocation truncated to fit: R_X86_64_32S against symbol `tmploc_' defined in COMMON section in output.o
output.f:(.text+0x451): relocation truncated to fit: R_X86_64_32S against symbol `tmploc_' defined in COMMON section in output.o
output.f:(.text+0x459): relocation truncated to fit: R_X86_64_32S against symbol `tmploc_' defined in COMMON section in output.o
output.f:(.text+0x461): relocation truncated to fit: R_X86_64_32S against symbol `tmploc_' defined in COMMON section in output.o
output.f:(.text+0x469): relocation truncated to fit: R_X86_64_32S against symbol `tmploc_' defined in COMMON section in output.o
output.f:(.text+0x471): relocation truncated to fit: R_X86_64_32S against symbol `tmploc_' defined in COMMON section in output.o
output.f:(.text+0x47a): relocation truncated to fit: R_X86_64_32S against symbol `tmploc_' defined in COMMON section in output.o
output.f:(.text+0x483): relocation truncated to fit: R_X86_64_32S against symbol `tmploc_' defined in COMMON section in output.o
output.f:(.text+0x48c): additional relocation overflows omitted from the output
make: *** [regcm] Error 1
but unfortunately I don't know what does this error mean?
Would you please let me know if you have any advice.
Thanks in advance,
zakey
TimP
Do you have a COMMON block larger than 2GB? That won't work with default memory model.
Martyn_C_Intel
Zakey,
Please see my article at http://software.intel.com/en-us/articles/avoiding-relocation-errors-when-building-applications-with-large-global-or-static-data-on-intel64/
In general, for errors like this, I encourage you to search the knowledge base, and then the forums, from http://software.intel.com/en-us/articles/advanced-search/
(orstart the search fromthe knowledge base at http://software.intel.com/en-us/articles/tools/- click on the binoculars).
Martyn
