remark #15346: vector dependence: assumed FLOW dependence between 117_dv_template line 91 and 117_dv_template line 91
AShte
I'm building a corray program with: -fast -qopt-report -g -coarray=distributed and I see this diagnostics in *optrpt: LOOP BEGIN at coback1.f90(90,5) remark #15344: loop was not vectorized: vector dependence prevents vectorization. First dependence is shown below. Use level 5 report for details remark #15346: vector dependence: assumed FLOW dependence between 117_dv_template line 91 and 117_dv_template line 91 remark #25439: unrolled with remainder by 4 LOOP END My code around lines 90-91 looks like this: 89 do j = 1, size2 90 do i = 1, width 91 pic(i,j) = 0.25 * ( oldpic(i-1,j) + oldpic(i+1,j) + & 92 oldpic(i,j-1) + oldpic(i,j+1) - edger(i,j) ) 93 end do 94 end do This is a simple Laplacian solver. What does "117_dv_template" refer to here? Thanks Anton
Xiaoping_D_Intel
It looks like the internal name of an array descriptor generated by the compiler for some array referenced at line 91. It shouldn't be exposed in the optimization report without being mapped back to the real array name in the code.
Is it possible for you to provide a standalone test case which can be compiled to reproduce the problem?
Xiaoping Duan
Intel Customer Support
AShte
I cannot reproduce this behaviour anymore.
However, extra white spaces indicate that some info
is missing:
      remark #15346: vector dependence: assumed FLOW dependence between  line 92 and  line 92
Anyway, I uploaded 2 files:
http://eis.bris.ac.uk/~mexas/pgmio.f90
http://eis.bris.ac.uk/~mexas/coback1.f90
I build the program with:
ifort -c -coarray -fast -qopt-report pgmio.f90
ifort -c -coarray -fast -qopt-report coback1.f90
ifort -coarray coback1.o pgmio.o
I get the following on the terminal:
ipo: warning #11021: unresolved MPI_Barrier
        Referenced in /cm/shared/languages/Intel-Compiler-XE-16-U2/compilers_and_libraries_2016.2.181/linux/compiler/lib/intel64_lin/libicaf.so
ipo: warning #11021: unresolved MPI_Comm_dup
ipo: warning #11021: unresolved MPI_Put
ipo: warning #11021: unresolved MPI_Get
ipo: warning #11021: unresolved MPI_Isend
ipo: warning #11021: unresolved MPI_Init
ipo: warning #11021: unresolved MPI_Free_mem
ipo: warning #11021: unresolved MPI_Win_unlock
ipo: warning #11021: unresolved MPI_Alloc_mem
ipo: warning #11021: unresolved MPI_Comm_size
ipo: warning #11021: unresolved MPI_Abort
ipo: warning #11021: unresolved MPI_Wait
ipo: warning #11021: unresolved MPI_Recv
ipo: warning #11021: unresolved MPI_Finalized
ipo: warning #11021: unresolved MPI_Comm_rank
ipo: warning #11021: unresolved MPI_Win_lock
ipo: warning #11021: unresolved MPI_Win_free
ipo: warning #11021: unresolved MPI_Win_set_errhandler
ipo: warning #11021: unresolved MPI_Win_fence
ipo: warning #11021: unresolved MPI_Win_create
Many thanks
Anton
Xiaoping_D_Intel
"-fast" option implies IPO (Inter-Procedure Optimization) enabled. Those warning message are generated in ipo linkage phase and can be safely ignored here. All the missing symbols are MPI functions defined in MPI runtime library.
I have opened a bug report to ask for removing the warnings. The bug report ID is DPD200411050.
Xiaoping Duan
