rtc_invalidate error
jbencray_com
We have built a hybrid MPI/OpenMP version of WRF with ifort 10.1.15. If we set OMP_NUM_THREADS=1 it runs without error. If we set OMP_NUM_THREADS=8 (or any other value) we see: "rtc_invalidate error".
This is running on Rocks+/CentOS5.0/2.6.18-53.1.14.el5 and Intel MPI 3.1
TimP
Quoting - jbencray.com
Intel MPI has made great strides in support of hybrid since 3.1, which hardly supported hybrid at all. Your report is amazingly cryptic. Do you set I_MPI_PIN_DOMAIN=omp, as required to work with OMP_NUM_THREADS ? Given that Red Hat 5.0 upheld the tradition of brokenness of .0 versions, why would you not use a recent version of Rocks? Rocks is up to RH/CentOS 5.3. ifort 10.1.15 also is fairly ancient, in the scheme of hybrid developments. The final update of ifort 11.0 has already been issued, and there were quite a few updates of 10.1 prior to that.
jbencray_com
Quoting - tim18
Thanks. OS and middleware upgrades are hampered by ISV support for the latest version. This is actually Rocks+ and the 5.1 version of Rocks+ just came out. I'll upgrade to ifort 11.0 and iMPI 3.2 as well as set I_MPI_PIN_DOMAIN=omp.
/jb
