running an executable ivf file on another computer
intel_ip
Am having a problem running an exe file created using ivf on another computer. Get the following error message: The program can't start because libifcoremdd.dll is missing from your computer.
Would appreciate a solution to this problem - thanks
mecej4
On the target machine where you want to run the program, you need to install the redistributables package. See https://software.intel.com/en-us/articles/redistributables-for-intel-parallel-studio-xe-2015-composer-edition-for-windows. You may need to install the Microsoft Visual C redistributables as well.
DavidWhite
Valued Contributor II
Alternatively, if you build your application with the Multithreaded option (/libs:static /threads), then the required DLL's will be included in the executable and you will not need to redistribute any other packages.
The consequence of doing this, however, is that your executables will be larger.
intel_ip
mecej4 wrote:
On the target machine where you want to run the program, you need to install the redistributables package. See https://software.intel.com/en-us/articles/redistributables-for-intel-par.... You may need to install the Microsoft Visual C redistributables as well.
Thanks very much. It worked well.
intel_ip
How does one  build an application with the Multithreaded option (/libs:static /threads)? - cheers
DavidWhite
In Visual Studio,
Select your project
Properties / Configuration Properties / Fortran / Libraries / Runtime Library
change the option from Multithreaded DLL to Multithreaded.
David
intel_ip
Thanks for your quick response.  Attached is a print screen of what is presently the option for 'runtime library'. Does that make sense?  So I should change this option to 'Multireaded', correct?
Thanks again for your help.
Cheers, Ian
DavidWhite
You'll want Debug MultiThreaded for the Debug build and Multithreaded for the Release build.
David
intel_ip
Thanks for the explanation!  I will try that.
Ian
intel_ip
Hi David:
Tried your suggestion and it worked well - thanks very much.
Ian
