Hi Fortran Folks,
I'm experimenting with the most efficient way to follow and sample high-frequency streaming timeseries into an array of fixed size.
This could be more of an "algorithms and datastructure" issue (Donald Knuth like), but as I expect, a typical problem for Fortran timeseries processing and hardware processor functionality too;
My Fortran app should process 10.000 arrays of size 10.000 each (or one type containing all arrays).
Every split of a second a new data-row is sampled (e.g. from an instrument or from stock exchanges) and inserted into the next free row. After the last row is reached, the oldest row is deleted and the new data can be inserted somehow. And so on, first out, last in. In time, the ORDERED array content looks kindlike 123, 234, 345...
---[1] I could shift the whole array before each insert at the end;
A(1:n-1) = A(2:n)
A(n) = newdata
---[2] Or implement some pointered linked list construction without array shift, replacing the oldest rows;
Time A1,2,3 P1,2,3
1 1 . . . . .
2 1 2 . . 1 .
3 1 2 3 . 1 2
4 4 2 3 3 . 2
5 4 5 3 3 1 .
6 4 5 6 . 1 2
7 7 5 6 3 . 2
8 7 8 6 3 1 .
9 7 8 9 . 1 2
In this way I have only one insertion in A and two in P each time.
---[3] Or use some smarter (faster) allocate/deallocate/pointer construction
---[4] Or some implicite function unknown to me, which is compiled to an extremely fast low level processing, using special (Intel) processor tasks and/or buffered I/O in the background ? Buffered I/O could be a requirement anyway.
---[5] Parallel HPF on quadcores (of course always an extra option for later).
Extreme efficiency is essential, and therefore as few instructions as possible.
I suppose there is a lot of experience in the Fortran world about algorithms and benchmarking of this kind of time series sampling, but couldn't find much yet.
Ideas and experiences are very welcome.
I'll post the results.
Thanks, Clemens de Leeuw (DaVinci)
In any case, option [1] is out of the question. Out of others (I'm not an expert on parallel execution), two schemes come to my mind. One is "plain vanilla" (nSamples,nSeries) matrix with reusable columns, with an additional "first row" indicator which changes as the new series arrive:
integer, parameter:: nSamples = 10000, nSeries=10000
real:: A(nSamples, nSeries)
integer:: ifirstcol
ifirstcol = 1
do while(something interrupts)
call ReadData(A(:,ifirstcol))
ifirstcol = mod(ifirstcol+1, nSeries) + 1
end doIn this way, your most recent data, in order, are A(:,ifirstcol), A(:,ifirstcol+1),..., A(:,nSeries), A(:,1), ...,A(:ifirstcol-1). IOW, you simply rewrite the oldest column each time, located at ifirstcol.
I'd venture a guess that this may end up as being the most efficient way. An alternative approach could be either with an array(nSeries) or a linked list of derived TYPEs, each containing an array of (nSamples) elements, or a circularly linked list of those same derived TYPEs. In linked list approach, you simply change the head pointer to the next one each time you receive the data (much the same as ifirstcol changes):
type t_mydata
type(t_mydata), pointer:: next
real:: data(nSamples)
end type t_mydata
type(t_mydata), target:: A(nSeries)
type(t_mydata), pointer:: Head
do i=1,nSeries-1
A(i)%next => A(i+1)
end do
A(nSeries)%next => A(1)
Head=>A(1)
call ReadData(Head%data)
Head=>Head%next
end do
I doubt there would be performance difference between those two, but if you need to involve ALLOCATABLE arrays of A or A%data, you will change the memory layout, for the good or the bad of it: it might be more memory-fragmentation friendly or less cache-friendly. In any case, you should do your own benchmarking.
Clemens,
Jugoslav had some good points.
Either a preallocatedarray or a linked listof arrays will work. There are some issues though to resolve regarding a "warmup" time between first sample and when the list of arrays become fully populated. Something along the lines of the following may be helpful
module foo
integer :: NumberOfArrays = 10000
integer :: ArraySize = 10000
integer :: Newest = 0
integer :: Oldest = 0
integer :: Insertion = 1
real, allocatable :: Array(:,:)
logical :: Done = .false.
end module foo
Program fooMain
use foo
allocate(Array(ArraySize, NumberOfArrays))
call StartSampleThread
do while(Oldest .eq. 0)
sleep(100)
end do
do while(.not. Done)
! process valid arrays
i = Oldest
do while(i .ne. Insertion)
call process(Array(:,i))
if(i .eq. Insertion) call BufferOverflowed
if(i .eq. Newest) exit ! finished
i = mod(i + 1, NumberOfArrays) + 1
end do
end do
end Program fooMain
subroutine process(workinArray)
use foo
real :: workingArray(ArraySize)
do j=1,ArraySize
end do
end subroutine process
subroutine InsertData
use foo
... ! insert data
Newest = Isertion
if(Oldest .eq. 0) Oldest = Newest
Insertion = mod(Insertion + 1, NumberOfArrays) + 1
if(Insertion .eq. Oldest) Oldest = mod(Insertion + 1, NumberOfArrays) + 1
end subroutine InsertData
Jim Dempsey
Thanks guys.
(always these fast solutions from Jugoslav, Jim,Steve(Steveprobably with a day off on the beach)). I'll implement these methods and reply with the benchmark results asap.
Clemens (davinci)
