29421 Discussions
second_INT_ETIME.f(53): error #6407: This symbolic name is not an intrinsic function name or an intrinsic subroutine name.
psing51
I am unable to compile lapack 3.5.0 library with intel , an i am getting following error:
ifort -O3 -fPIC -c lsame.f -o lsame.o
ifort -O3 -fPIC -c lsametst.f -o lsametst.o
ifort  -o testlsame lsame.o lsametst.o
ifort -g -O0 -fPIC -c slamch.f -o slamch.o
ifort -O3 -fPIC -c slamchtst.f -o slamchtst.o
ifort  -o testslamch slamch.o lsame.o slamchtst.o
ifort -g -O0 -fPIC -c dlamch.f -o dlamch.o
ifort -O3 -fPIC -c dlamchtst.f -o dlamchtst.o
ifort  -o testdlamch dlamch.o lsame.o dlamchtst.o
ifort -O3 -fPIC -c second_INT_ETIME.f -o second_INT_ETIME.o
second_INT_ETIME.f(53): error #6407: This symbolic name is not an intrinsic function name or an intrinsic subroutine name.   [ETIME]
      INTRINSIC          ETIME
compilation aborted for second_INT_ETIME.f (code 1)
make[1]: *** [second_INT_ETIME.o] Error 1
make[1]: Leaving directory `/opt/user1-INTEL/finaluser1/ToolsInstaller/common_dependency/lapack-3.5.0/INSTALL'
  ASCII character set
  Tests completed
  Epsilon                      =   5.9604645E-08
  Safe minimum                 =   1.1754944E-38
  Base                         =    2.000000
  Precision                    =   1.1920929E-07
  Number of digits in mantissa =    24.00000
  Rounding mode                =    1.000000
  Minimum exponent             =   -125.0000
  Underflow threshold          =   1.1754944E-38
  Largest exponent             =    128.0000
  Overflow threshold           =   3.4028235E+38
  Reciprocal of safe minimum   =   8.5070592E+37
  Epsilon                      =   1.110223024625157E-016
  Safe minimum                 =   2.225073858507201E-308
  Base                         =    2.00000000000000
  Precision                    =   2.220446049250313E-016
  Number of digits in mantissa =    53.0000000000000
  Rounding mode                =    1.00000000000000
  Minimum exponent             =   -1021.00000000000
  Underflow threshold          =   2.225073858507201E-308
  Largest exponent             =    1024.00000000000
  Overflow threshold           =   1.797693134862316E+308
  Reciprocal of safe minimum   =   4.494232837155790E+307
/bin/sh: line 1: ./testsecond: No such file or directory
/bin/sh: line 1: ./testdsecnd: No such file or directory
/bin/sh: line 1: ./testieee: No such file or directory
/bin/sh: line 1: ./testversion: No such file or directory
Many other users are also getting this kind of error , but their fix is not working in my case!
I understand that intel compiler suite includes mkl (having blas lapack implementations) , but i want to compile the lapack with intel compilers just to test the performance improvement when the same is compiled with gnu compiler suit!
make.inc is attached herewith.
Eagerly awaiting your reply.
TimP
Which advice didn't work?  How about removing that bogus intrinsic and instead USE IFPORT or replace etime by a Fortran standard intrinsic?
Note the instructions supplied with lapack on how to configure for CPU_time.
mecej4
Before building Lapack you have to adapt make.inc. For IFort (and most modern F95+ compilers) select TIMER    = INT_CPU_TIME.
