28994 Discussions
the difference between "start debugging" and "start without debugging"
jackmwl
Hi all
I have the wrong result orpart of the program cannot work when using "start without debugging"in Debug Configuration in VS2008+IVF11.1.060. Then I run the programin Release Configuration, whichhad the same result asin Debug. But when the program used "start debugging" in Debug Configuration, it worked correctly.
So what is the difference between "start debugging" and "start without debugging" in Debug Configuration? What should i do?
Any help would be highly appreciated!
Best regards
Jack
jimdempseyatthecove
Jack,
Check for uninitialized variable usage.
Starting with Debugging may present your program with different "junk" than starting without debugging.
Do not assume uninitialized variables are 0 or 0.0.
Jim Dempsey
jackmwl
Hi Jim,
Thanks for your reply!
I find my mistake in the program. There is an uninitialized array.
Best regards
Jack
