the -lowercase option
fboyer
Is there a way to disable the default option -lowercase used
by the ifc compiler ?
I want to link a fortran code with a C library but the names of the functions in the library are case-sensitive and contain both upper and lowercase letters ...
Thanks for your help.
F.
TimP
Apparently, the options are -lowercase or -uppercase. No doubt you're aware this isn't the only issue which might require you to write Fortran-callable wrapper functions in C.
I suggest the use of !DEC$ ATTRIBUTES ALIAS to specify the exact name you want, rather than changing the interpretation of all names. See the documentation for information on how to use the ATTRIBUTES directive.
Steve
