/tune vs /arch in CVF6
rahzan
What is the:
1. Diffrence
2. Interaction
between settings on /arch and /tune ?
e.g. does one supersede the other, or do they compliment each other or...?
thanks,
Tim H
They complement each other.
/arch says "generate instructions that assume the program is being run on a processor of at least this generation". This can cause use of instructions not supported on older processors.
/tune says "when making optimization decisions, choose the sequence that works best on this processor generation." You can use /tune without /arch, in which case the program will run everywhere but may run a bit slower on processor generations older than the one you specified.
The same applies to CVF on IA-32 systems.
Steve
rahzan
Thank stevo,
That is what I assumed.
So assuming the exe/dll is never distributed, then specifying /arch=host completely supersedes /tune=host.
Correct?
Tim
Supersedes? I don't think I'd put it that way, but in practice it might work out like that.
Steve
