type variable pre-allocated + error
diedro
Dear all,
I am probably doing something that is not possible.
I have created this variable in a general module:
  TYPE tresultVar
     REAL     :: pmean   ! posterior mean for variable i
     REAL     :: PM(4)
     REAL     :: pstd    ! posterior std deviation
     REAL     :: PR(4)
     REAL     :: NSET(4) !
  ENDTYPE
After that I call a subroutine as:
CALL APMSUB(nVar,resapmVAR,res1RESULTSVAR,res2RESULTSVAR)
and the subroutione look like:
SUBROUTINE APMSUB(nVar,resultGV,result1V,result2V)
  USE VARS_DIAGNOSTIC
  USE mod_alngam
  IMPLICIT NONE
  INTEGER             :: nVar
  TYPE(tresultVar)    :: resultGV(nVar)
  TYPE(tresultVar)    :: result1V(nVar)
  TYPE(tresultVar)    :: result2V(nVar)
The var type in in the module  VARS_DIAGNOSTIC
Where I write:
WRITE(*,*) size(resultGV(iVar)%PM)
I get, as expected: 4
However, if a write:
WRITE(*,*) resultGV(iVar)%PM
I get an error.
What am I doing wrong?
I am trying to do something that is not possible?
Thanks for any helps
Diedro
Juergen_R_R
Valued Contributor I
Diedro, this is not s a complete code. All examples I tried to make from it, compiled. You get an error? What kind of error? A compilation error, a runtime error, the computer froze? You have to give more information.
diedro
Dear Juergen R. Dear all,
you are right. I get the following error:
forrtl: severe (174): SIGSEGV, segmentation fault occurred
Image              PC                Routine            Line        Source
a.out              0000000000460BBD  Unknown               Unknown  Unknown
libpthread-2.23.s  00007F69D3F49390  Unknown               Unknown  Unknown
Really thanks for any kind of help
Juergen_R_R
That is a little more information, but not yet enough. So the program compiles and then exhibits a runtime error. The fact that the pthread library appears there raises my suspicion that you are linking some external tool/library into your program which uses more than one thread, and then you do a write operation. But possibly one needs a full reproducer here.
diedro
Dear Juergen R., dear all,
I have no  external tool/library. However, I will try to make a simple test case by the end of tomorrow.
Thanks for the suggestions,
Diedro
diedro
I have understood the error doing the test case. So really thanks for your suggestions.
I attach the test case hoping that it can help in understanding this post,
again, really really thanks
FortranFan
diedro wrote:
.. I attach the test case hoping that it can help in understanding this post, ..
@diedro,
I'll suggest you provide specific details on the code you are using and steps you are taking to compile and link and execute to get prompt and relevant guidance.  Here's an example using a Windows console of what one can do:
C:\Temp>type VARS_DIAGNOSTIC.f90
MODULE VARS_DIAGNOSTIC
  TYPE tresultVar
     REAL     :: PM(4)
  ENDTYPE
ENDMODULE
C:\Temp>ifort /c /standard-semantics /warn:all /stand VARS_DIAGNOSTIC.f90
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.0.1.144 Build 20181018
Copyright (C) 1985-2018 Intel Corporation.  All rights reserved.
C:\Temp>type MOD_TEST_SUB.f90
MODULE MOD_TEST_SUB
 CONTAINS
 SUBROUTINE TEST_SUB(nn,VARIN)
 USE VARS_DIAGNOSTIC
 IMPLICIT NONE
 INTEGER :: nn
 TYPE(tresultVar) ::  VARIN(nn)
 VARIN(1)%PM(1) = 1.
 WRITE(*,*) VARIN(1)%PM
 ENDSUBROUTINE
ENDMODULE
C:\Temp>ifort /c /standard-semantics /warn:all /stand MOD_TEST_SUB.f90
C:\Temp>type TEST.f90
PROGRAM TEST
USE VARS_DIAGNOSTIC
USE MOD_TEST_SUB
IMPLICIT NONE
INTEGER :: nVar
TYPE(tresultVar) , ALLOCATABLE:: VAR(:)
nVar = 5
ALLOCATE(VAR(nVar))
CALL TEST_SUB(nVar,VAR)
ENDPROGRAM
C:\Temp>ifort /c /standard-semantics /warn:all /stand TEST.f90
C:\Temp>link TEST.obj MOD_TEST_SUB.obj VARS_DIAGNOSTIC.obj /subsystem:console -out:test.exe
Microsoft (R) Incremental Linker Version 14.16.27026.1
Copyright (C) Microsoft Corporation.  All rights reserved.
C:\Temp>test.exe
 1.000000 1.1095753E+27 2.6785321E+20 1.9345917E-19
C:\Temp>
