uninit check failed
SCHWOERTZIG_T_
I am wondering why uninit check does not detect uninit variable in the following program. Is there a way to detect such situations ?
       PROGRAM UNINIT_FAILED
       IMPLICIT NONE
       INTEGER VAR
         CALL DO_NOTHING(VAR)
         VAR=VAR+0
         print *, "VAR=", VAR
       END
       SUBROUTINE DO_NOTHING(MYVAR)
       IMPLICIT NONE
       INTEGER MYVAR
         RETURN
       END
Thank you very much for your help.
Thierry
The compiler's run-time uninitialized variable checking is quite limited, unfortunately. It checks static, local scalars only and does not do cross-routine checking. Your error would be caught by the Static Analysis feature of Intel Fortran Studio XE, however. capture.png
SCHWOERTZIG_T_
Thank you very much for your help. Thierry
