29386 Discussions
use of scigraph ? (fatal error lnk 1181 related to scigraph.lib)
kelaynak
I tried to use scigraph in quickwin of IVF10.1014. There is a demo file sgdemo.f90. While building solution, it is giving the below error;
fatal error lnk1181;cannot open input file scigraph.lib
Before using it , I had done the following changes in VS 2005;
1)Tools menu in VS2005> added c:program filesintelcompilerfortrania32include to include directory
and c:program filescompilerfortrania32lib to lib directory
2) Projects>project properties>linker>additional dependincies>added scigraph.lib.
3) I did not change anything in sgdemo.f90
I also checked ."...compilerfortrania32lib" directory, I could not see scigraph.lib.Shouldit be there or not?If yes, I think I deleted it in somehow.
Would you pleasegive anysuggestion how tosolve this error related scigraph.
Thanks in advance
You should not have done item 2 - that is causing the error. I am not sure why you made the changes in item 1, they are also not necessary. Just open the Scigraph solution and build it.
kelaynak
Thank you very much. Yes it has worked without any problem when changing nothing.
I read the following article in the forum "using Scigraph plotting library" (on 03/02/2006). I think I misunderstood the reply of Les Neilson to that article. Anyway, you corrected me. Now it is clear.
Thank you
