using video with Fortran
NSwindale
I would like to write a program that can access a video device (e.g .a webcam). That means calling functions in vfw.h. Is there an interface module?
For example,  the line:
case (ID_FILE_VIDEOCAPTURE)
   hWndC=capCreateCaptureWindow('My Capture Window'C, IOR(WS_CHILD,WS_VISIBLE), 0, 0, 160, 120, ghwndClient, nID)
gives an unresolved external symbol error.
I have tried various USE statements to no avail e.g. USE IFWINTY  and USE IFPORT
NickS
Labels (2)
andrew_4619
Avicap32/Vfw does not exist in the Fortran include modules. You will need to create your own interfaces.
NSwindale
Thank you!
I am wondering how one finds out which modules to use for which functions other than just trying - or wading through the modules themselves.
Steve_Lionel
Here's an interface to this routine - you may need others. You'll want to USE this module, add to it as needed.
module Vfw32
use IFWINTY
implicit none
interface
function capCreateCaptureWindow (lpszWindowName, dwStyle, x, y, nWidth, &
  & nHeight, hwndParent, nID) bind(C,name="capCreateCaptureWindowA")
import
!DIR$ ATTRIBUTES STDCALL :: capCreateCaptureWindow
integer(HANDLE) :: capCreateCaptureWindow
character, dimension(*), intent(IN) :: lpszWindowName
integer(DWORD), value, intent(IN) :: dwStyle
integer(DWORD), value, intent(IN) :: x, y, nWidth, nHeight
integer(HANDLE), value, intent(IN) :: hwndParent
integer(DWORD), value, intent(IN) :: nID
end function capCreateCaptureWindow
end interface
end module Vfw32
NSwindale
Thank you very much - most helpful. I'll also check for updates re. the next message.
Shiquan_Su
The code example here has been passed to the proper group for further work.
Steve_Lionel
Look up the documentation of the function on Microsoft's site. For example,  capCreateCaptureWindowA function (vfw.h) - Win32 apps | Microsoft Docs
Towards the bottom of the page, look to see which Library it is defined in. For example:
Here we see it is in library Vfw32.lib. If Intel provides a module for this, it is the same as the library name, VFW32 in this case. But that module is not in the Intel set.
You can, of course, always search the compiler's Include folder for the name of the routine you want to see if there's a hit.
During my time at Intel, I did a LOT of work on the Windows API modules, updating some and creating some new ones when I saw requests. I don't recall ever seeing this library come up before.  Creating and updating these modules is a lot of hard work, and Microsoft adds new APIs faster than I could add them to modules. Before I retired, I managed to get KERNEL32 mostly up to date, with changes in USER32 and some others.
NSwindale
Over the years I have come to appreciate the huge amount of work that must have gone into making so much of the Windows API accessible to Intel Fortran programmers. It has always been there when I needed it and it has enabled very many useful things (except until now - and I don't mind having to write a few interface routines having seen an example). Thanks so much - enjoy your retirement.
Steve_Lionel
I just realized that I messed up the module I created for you by omitting the value attribute where it was needed. I have edited the reply above.
mfinnis
New Contributor III
For what it's worth, this is a module I used when I did some video stuff a few years ago.
NSwindale
That could be very useful - I will try it.
Nick
Ron_Green
We can add this Interface.  But we need a good sample or testcase to see if it works.  Does anyone have a small-ish sample code?
thanks
Ron
Steve_Lionel
Ron, I'm not sure what brought you back to this thread, but if you were to do something here it would be to add a module defining everything in vfw.h, which is quite a lot.
Ron_Green
and would require a lot of tests to insure quality and no regressions.
We have a Feature Request based on this thread for this specific interface.  I think we can close it as 'wont fix' or morph it into a FR for a vfw module.
NSwindale
I think I am the person who started this thread some years ago. I just checked and found that I ended up using the code link sent by mfinnis above to create a VFW32 module. It contained what I needed - that may be enough at this point and the thread can be closed as far as I am concerned.
Belated thanks!
