vs code
tchakounang
I am using VS Code and ifort. I would like to watch a matrix while debugging, but it doesn't work.
Can someone tell me if a solution has been found and explain how to solve this issue?
Thank you.
jimdempseyatthecove
If the matrix (array) is located in a module (example "YourModule"), then you must prefex the name of the matrix (array) with the module name (similar to the scoping annotation in C++)
YourModule::YourMatrix
If need be, you can place index ranges (iow a slice of the matrix/array)
Jim Dempsey
