warning #5117: Bad # preprocessor line
LI_S_
I'm trying to compile a fortran project with /fpp option on visual studio 2013, and it keeps giving me a warning:
And it looks like the code hasn't been passing through to the preprocessor.
The code is as simple as this:
      logical*1 FUNCTION IsPreprocesorDefined()
      IsPreprocesorDefined= .false.
      #ifdef  PRO_PROC_DEFINED
      IsPreprocesorDefined= .true.
      #endif
      return
      end
The compiler I'm using is Intel(R) Visual Fortran Compiler XE 15.0.4.221 [IA-32]
Can anyone point me to the right direction?Thanks very much
LI_S_
hello anyone?
why the status of the post is still draft?
Steven_L_Intel1
Please attach a ZIP of the buildlog.htm showing the error. I'd expect this message if in fact /fpp wasn't being used.
jimdempseyatthecove
Did you change this option to all your project files... and build platforms?
Are you adding this switch to the "miscellaneous"/additional options...
... or did you check the Preprocess(or) check box in the VS Project properties? (and for all builds)
Jim Dempsey
