I get a warning like warning #7799: %LOC is being stripped from argument which has REFERENCE and IGNORE_LOC attributes. [ILEN] from a code ;like
iret = RegQueryValueEx( hKey, & "Data4"C, & NULL, & NULL, & LOC(Buff),& LOC(iLen))
If I use just iLen rather than LOC(iLen) the call doesn't return a value representing the length of the registry value. iLen is declared as an Integer(4) variable. If I use the LOC() then I get the length of the registry value. So how do I code this so I don't get the warning but I do get the length correct?
I'm using VS2013 Community with PSXECE 2017 Rel 2.
Brooks
Ok, I see what's causing the warning about ILEN in x64 - the declaration in module ADVAPI32 uses INTEGER(LPDWORD) for that argument. That was correct when IGNORE_LOC and REFERENCE were not specified, but not now. It should be INTEGER(DWORD). This mismatch is also what is causing ilen to not be set properly. The program I posted runs fine in 32-bit, but not 64-bit. You had not said earlier you were building for x64.
The only workaround I can think of is to make your own definition of the routine. For example:
INTERFACE FUNCTION RegQueryValueEx( & hKey, & lpValueName, & lpReserved, & lpType, & lpData, & lpcbData) use ifwinty integer(LONG) :: RegQueryValueEx ! LONG !DEC$ ATTRIBUTES DEFAULT, STDCALL, DECORATE, ALIAS:'RegQueryValueExA' :: RegQueryValueEx integer(HANDLE) hKey ! HKEY hKey !DEC$ ATTRIBUTES REFERENCE, ALLOW_NULL :: lpValueName character*(*) lpValueName ! LPCSTR lpValueName integer(LPDWORD) lpReserved ! LPDWORD lpReserved !DEC$ ATTRIBUTES REFERENCE, ALLOW_NULL, IGNORE_LOC :: lpType integer(DWORD) lpType ! LPDWORD lpType integer(LPBYTE) lpData ! LPBYTE lpData !DEC$ ATTRIBUTES REFERENCE, ALLOW_NULL, IGNORE_LOC :: lpcbData integer(DWORD) lpcbData ! LPDWORD lpcbData END FUNCTION END INTERFACE
and then when you do the use, rename the bad one away:
use ADVAPI32, NotUsed => RegQueryValueEx
Note that I also fixed the declaration of lpType. One of the Intel folk, please ask the RTL people to fix this.
There is a specific option that warns about %loc. A standard conforming but clumsy looking way is transfer(c_loc(var,0_handle)
Seems to work for me...
program Console7 use advapi32 implicit none ! Variables character(100) :: buf integer(DWORD) :: ilen, ret integer(HANDLE) :: hkey ret = RegOpenKeyEx (HKEY_LOCAL_MACHINE, & "SOFTWARE\Microsoft\Windows\CurrentVersion"//""C, & 0, & KEY_READ, & hkey) if (ret /= ERROR_SUCCESS) then print *, "Open Key failed with status ", ret stop end if ilen = len(buf) ret = RegQueryValueEx ( & hkey, & "ProgramFilesDir"//""C, & NULL, & NULL, & LOC(buf), & ilen) if (ret /= ERROR_SUCCESS) then print *, "Query failed with status ", ret else print '(A,A,A)',"Value is '",buf(1:ilen),"'" end if end program Console7
Value is 'C:\Program Files (x86) '
Brooks are you using the Intel version of of the RegQueryValueEx interface in IFWIN/advapi32 or are you supplying your own?
Andrew, I am not using my own. Steve, the reason your code works is that the returned value has a C type zero at the end. If you had left off the range of buf it still would have printed correctly but the value of iLen would still be 100. See my first comments.
Brooks
Andrew, how do you access transfer(c_loc(var,0_handle). I can find neither C_LOC nor Transfer in the include files.
Brooks
transfer is intrinsic. c_loc is in USE ISO_C_BINDING
Brooks, your comment about my example is not correct. I modified it to print the value of ilen, and get:
Value is 'C:\Program Files (x86) ', length 23
The 23 includes the trailing NUL, which is why a blank prints at the end. Try it yourself.
If you still think there is a problem, please post your own example (using some common registry entry.)
Steve, if I make your change i get warning #6075: The data type of the actual argument does not match the definition. [ILEN] which just replaces a warning about %LOC() to one of the wrong data type. I have to use Integer(PDWORD) rather than Integer(DWORD).
Brooks
I'm not understanding what you changed. All I was saying in post 8 was that I added ILEN to the PRINT statement - no other changes.
Please show a complete example that demonstrates the problem. Feel free to use my version as a starting point.
Steve,
I took your code and put it into an x64 msvc project and compiled it. Here is what I got:
------ Build started: Project: Console7, Configuration: Debug x64 ------
1>Compiling with Intel(R) Visual Fortran Compiler 17.0.2.187 [Intel(R) 64]...
1>Console7.f90
1>c:\users\brooks\documents\visual studio 2013\Projects\Console7\Console7\Console7.f90(27): warning #6075: The data type of the actual argument does not match the definition. [ILEN]
So reread my last post. Doing it your way gets rid of a warning for '%LOC()' but replaces it with a different warning of #6073.
Brooks
Steve,
Also I could not run your program because I get
INK : fatal error LNK1561: entry point must be defined
Brooks
Thanks very much Steve. That fixed the problem!
Brooks
This got fixed in 18.0.2.
