The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
27547 Discussions
weird warning with round-remapping list in pointer
Aldo_H_
Could it be that warning 8589 is wrong if the data target is simply contiguous?
A complete minimal program would be this ('main.f90'):
real, target  :: rank2_data(10,10)
real, pointer :: rank1_ptr(:)
rank1_ptr(1:100) => rank2_data
end
Compiling with `ifort -stand f15  main.f90`, I get main.f90(3): warning #8589: Fortran 2015 specifies that if a bound remapping list is specified, data target must be of rank one.   [RANK2_DATA]. I'm using ifort version 18.0.1.
Juergen_R_R
Valued Contributor I
I think you are correct. The warning is no longer flagged in the beta version of ifort 19.
Aldo_H_
Is it more than a misguided warning? That is, is there a special reason to suspect that rank-2 data targets do not compile correctly?
Steve_Lionel
Black Belt Retired Employee
The F2008 standard says:
If bounds-remapping-list is specified, the pointer target shall be simply contiguous (6.5.4) or of rank one.
The F2018 draft standard says:
If bounds-remapping-list appears, it specifies the upper and lower bounds of each dimension of the pointer, and thus the extents; the pointer target shall be simply contiguous (9.5.4) or of rank one, ...
Note that both standards say that the target shall be either "simply contiguous" or of rank one. If the compiler is ignoring the "simply contiguous" case, that's incorrect (and the message's wording is incorrect regardless.)
In your example, the target is indeed "simply contiguous".
