Hi
I use Intel Fortran compiler. my array is 2 dimensions an it's boundary is between 1 to 16.
this is my code and why fortran print a(0,0) and a(17,17) equal to 0 and 0
program hirarchichal_detreministic implicit none integer, parameter:: N=4 !initial core integer, parameter:: ns=1 !number of steps integer, parameter:: nn = n**(ns+1) integer, dimension (1:nn,1:nn):: a !adjacency matrix integer:: i, j, k, ii, m, l real::p(nn) open(1,file='out') a = 0 print*,sum(a), a(0,0), a(17,17) pause !****************************************** !initial fully connected network; ns=0 a(1:n,1:n)=1 do i=1,n a(i,i)=0 enddo !****************************************** print*,sum(a), a(0,0), a(17,170) do i=1,ns do k= 2, n-1 do ii= k*(n**i)+1, (k+1)*(n**i) do j=k*(n**i)+1, (k+1)*(n**i) !print*,i,k,ii,j l = mod(ii,n**i+1) m = mod(j,n**i+1) a(ii,j) = a(l,m) print '(20(I2,2x))',sum(a), i, k, ii, j, l, m enddo ! pause enddo enddo enddo print*,"fd" Do i=1, nn !k=sum(a(1:nn,i)) !p(k)=p(k)+1. do j=1,nn write(1,*)i,j, a(i,j) enddo enddo p=p/sum(a) print*,"fd/" do i=1,nn write(1,*)i,p(i) enddo end
A segmentation fault occurs when the resolved address resides within a virtual memory page that has not been assigned (an marked as not assignable). For a valid array, indexing 1 or a few element before or after the addresses of the array typically resolve to mapped addresses (which in Fortran-speak are undefined). Using bounds checking in most cases will catch these errors. In some cases where the array is a dummy argument, the dummy argument can potentially be specified with incorrect bounds with respect to the actual argument. In these cases the bounds checking asserts the bounds specified for the dummy argument as opposed to the actual argument at the call.
Jim Dempsey
You need to compile with the compiler options set properly. For example,
ifort -check all drb.f90 <other options that you need>
will add the code to check the bounds at run-time.
why not a segmentation fault error?
Jim Dempsey
Because a(17,17) simply refers to the same address in memory as p(11), assuming no padding and, therefore, sequential allocation of a(,), followed by the six integers, and then p. Thus, the address of a(17,17) is still within the memory block allocated for use by your program.
More simply, given the declaration
Integer a(2), b(3)
a run-time reference to a(4) is the same as a reference to b(2). This is why you need a finer check on individual variables rather than the whole block of memory that the program "owns".
