win32 Function Question
gelarimer
I am attempting to get the disc free space available for a user with the following:
INTEGER(4) iret
INTEGER(8), TARGET :: iFB
INTEGER(8), POINTER :: pFB
TYPE(T_LARGE_INTEGER) iFreeBytes
pFB => iFB
iret = GetDiscFreeSpaceEX('H:'C, iFreeBytes,
NULL, NULL)
! because 8 bytes are contiguous in memory
pFB = LOC(iFreeBytes)
From Exporer I know thedisc has about 129GBs of free disc space, however, when I execute the code above iFB shows only about 5MBs of free space.
Is the use ofthe pointer pFB correct in the code above?
I also noticed that the sign bit was set for the LowPart whichalso appears to be a problem:
iFreeBytes%LowPart = -1525272576
iFreeBytes%HighPart = 3
Any comments would be appreciated. Thanks in advance.
anthonyrichards
New Contributor III
This version works. I use Compaq Visual Fortran 6.6C, but you should be able to see what changes to make for IVF. Note I cannot do 64-bit integer arithmetic, so I converted to REAL arithmetic and did the sums andI checked the values it gave me doing the sum indicated against values given by Explorer and they were identical. Note the double back-slash needeed for the folder C-string and I had to use GetDisKFreeSpace with a 'K' in DisK rather than a 'C'.
program freespace
use kernel32
use dfwin
implicit none
REAL(8) Callerbytes, Threadbytes, Totalbytes, Factor
INTEGER(4) iret
TYPE(T_LARGE_INTEGER) iCallerBytes, iThreadBytes, iTotalBytes
character(10) Folder
folder='C:'C
iret = GetDiskFreeSpaceEx(folder, iCallerBytes, iThreadBytes, iTotalBytes)
print *,' IF LOWPART is >0, Total bytes = 2**32 x HIGHPART + LOWPART'
print *,' IF LOWPART is <0, Total bytes = 2**32 x (HIGHPART+1) + LOWPART'
print *
print *,' HIGHPART LOWPART'
print *,'bytes free to Caller = ',iCallerbytes%highpart,' ', icallerbytes%lowpart
print *,'bytes free to Thread = ',iThreadbytes%highpart,' ', iThreadbytes%lowpart
print *,'bytes free Total = ',iTotalbytes%highpart, ' ',iTotalbytes%lowpart
factor=2.0d+00**32
if(icallerbytes%lowpart<0) then
Callerbytes=factor*(dble(iCallerbytes%highpart+1))+dble(icallerbytes%lowpart)
else
Callerbytes=factor*(dble(iCallerbytes%highpart))+dble(icallerbytes%lowpart)
endif
if(ithreadbytes%lowpart<0) then
threadbytes=factor*(dble(ithreadbytes%highpart+1))+dble(ithreadbytes%lowpart)
else
threadbytes=factor*(dble(ithreadbytes%highpart))+dble(ithreadbytes%lowpart)
endif
if(itotalbytes%lowpart<0) then
totalbytes=factor*(dble(itotalbytes%highpart+1))+dble(itotalbytes%lowpart)
else
totalbytes=factor*(dble(itotalbytes%highpart))+dble(itotalbytes%lowpart)
endif
print *,'bytes free to Caller = ',Callerbytes
print *,'bytes free to Thread = ',Threadbytes
print *,'bytes free Total = ',Totalbytes
end program freespace
OUTPUT FOLLOWS:
 HIGHPART LOWPART
bytes free to Caller = 5 1557180416
bytes free to Thread = 9 -1000779776
bytes free Total =&nbs p; 5 1557180416
bytes free to Caller = 23032016896.0000
bytes free to Thread = 41948893184.0000
bytes free Total = 23032016896.0000
Press any key to continue
gelarimer
ThanksAnthony.May have questions afterI study yourcode.
joerg_kuthe
Here is an sample program which might be easier to use. I simply copied the INTERFACE from KERNEL32.f90 and changed those ULONGLONG args into INTEGER*8. So you don't have to considerthose sign bits.
Joerg Kuthe
www.qtsoftware.de
PROGRAM
T_GetDiskFreeSpaceEx
USE IFWINTY
USE KERNEL32
IMPLICIT NONE
INTEGER :: iRet
INTEGER(8) lpFreeBytesAvailableToCaller ! PULARGE_INTEGER lpFreeBytesAvailableToCaller
INTEGER(8) lpTotalNumberOfBytes ! PULARGE_INTEGER lpTotalNumberOfBytes
INTEGER(8) lpTotalNumberOfFreeBytes ! PULARGE_INTEGER lpTotalNumberOfFreeBytes
CHARACTER(*), PARAMETER :: szDir = 'C:'C
INTERFACE
FUNCTION qtGetDiskFreeSpaceEx( lpDirectoryName, lpFreeBytesAvailableToCaller, lpTotalNumberOfBytes, lpTotalNumberOfFreeBytes)
use ifwinty
integer(BOOL) :: qtGetDiskFreeSpaceEx ! BOOL
!DEC$ ATTRIBUTES DEFAULT, STDCALL, DECORATE, ALIAS:'GetDiskFreeSpaceExA' :: qtGetDiskFreeSpaceEx
!DEC$ ATTRIBUTES REFERENCE, ALLOW_NULL :: lpDirectoryName
CHARACTER*(*) lpDirectoryName
!DEC$ ATTRIBUTES REFERENCE, ALLOW_NULL :: lpFreeBytesAvailableToCaller
!DEC$ ATTRIBUTES REFERENCE, ALLOW_NULL :: lpTotalNumberOfBytes
!DEC$ ATTRIBUTES REFERENCE, ALLOW_NULL :: lpTotalNumberOfFreeBytes
END FUNCTION
END INTERFACE
iRet = qtGetDiskFreeSpaceEx( szDir, lpFreeBytesAvailableToCaller, lpTotalNumberOfBytes, &
lpTotalNumberOfFreeBytes )
IF ( iRet /= 0 ) THEN
WRITE(*,6000) szDir(1:3)
6000 FORMAT('Size of Directory "', A '"')
CALL CS_PrintResult( 'Free Bytes Available To Caller', lpFreeBytesAvailableToCaller )
CALL CS_PrintResult( 'Total Number Of Bytes', lpTotalNumberOfBytes )
CALL CS_PrintResult( 'Total Number Of Free Bytes', lpTotalNumberOfFreeBytes )
ELSE
PRINT*,'GetDiskFreeSpaceEx() failed; error = ', GetLastError()
END IF
CONTAINS
SUBROUTINE CS_PrintResult( cText, i8MemVal )
CHARACTER(*), INTENT(IN) :: cText
INTEGER(8), INTENT(IN) :: i8MemVal
WRITE(*,6000) TRIM(cText), i8MemVal, i8MemVal / (1024.*1024.)
6000 FORMAT(A, ' = ', I0, ' (= ', F0.3, ' MB)')
END SUBROUTINE CS_PrintResult
END
PROGRAM
gelarimer
Thanks for both replies. I was stumped for a little while about the math used inanthonyrichardsexample code, but after a littlebinary math realized that Fortran displays the two's compliment +1 of the binary when the sign bit is set.A little binary math demonstrated thatadding 1 to theHighPart and multiplying by factorand then adding the negative LowPart actuallyproduces the correct result.
In the second example,I realize that the HighPart and LowPart of the structure Large_Integer (filled in by the Win32 fn.) are contiguous in memory, and thatSTDCALL means that actual values are returned in the Win32 function arg list.However, not clear on how returning actual values for a C structure works in an arg list. Sincecode works fine, I assume that the arg or returned values for theC structure will always be just 8 contiguous Bytes. Is there anyrisk that manipulating the INTERFACE in this way may cause unexpected problems?
joerg_kuthe
All arguments in the
are returned by REFERENCE (STDCALL passes arguments by VALUE, so you have to change the interface). This means, not the value itself is returned but the starting address of memory where the values of
are found. The type information then specifies how many bytes have to be considered to obtain thevalue.So you can handle any size of argument.
I don't see a risk in the kind of manipulation that I have made because I simply gave those 8-bytes being addressed just another type of the same memory sizeas expected(INTEGER(8)).
It is your decision how you want your compiler to handle those arguments. So you choose what suits your needs best.
Joerg Kuthe
www.qtsoftware.de
gelarimer
Thanks forthe explanation about how memory was treated.
I was fixated on the ATTRIBUTES STDCALL for qtGetDiskFreeSpaceEX(),but now seethat the ATTRIBUTES REFERENCEyou gave to the arguments overrides pass by value.
Trying to learnabout INTERFACE Blocks, and your example helped quite a bit.
