wrong error with omp-collapse
valery_w_
dear all
the following code is producing a wrong error.
thanks
v
ifort -v
ifort version 14.0.1
cat ifort_14.0.1_collapse.f90
subroutine test
  real :: r(3,3,3)
  integer :: i, j, k
  !$omp do collapse(3)
  do 66 k=1,3
  do j=1,3
  do i=1,3
     r(i,j,k) = 0.0
  enddo
  enddo
66 continue
end subroutine test
ifort -c -openmp ifort_14.0.1_collapse.f90
ifort_14.0.1_collapse.f90(4): error #8194: The COLLAPSE clause requires perfectly nested loops:  no code may appear before or after the loops being collapsed.
compilation aborted for ifort_14.0.1_collapse.f90 (code 1)
TimP
I see that this particular problem is associated with the old-style label on the do termination statement.  There are multiple ways the label could be used "illegally" although that's not the case here.
Thanks - escalated as issue DPD200250517. As I'm sure you already know, replacing the outer nonblock-DO with a block-DO avoids the error.
This has been fixed for a major release later this year.
