I'm using Intel Fortran 18.0.1.163 on a system with KNL cpus on the compute nodes. Here is my test code,
module align_test_module implicit none contains subroutine do_something(nVertLevels) integer, pointer :: nVertLevels integer :: i real, dimension(:), allocatable :: uTemp allocate(uTemp(nVertLevels)) !$omp simd aligned(uTemp:64) do i = 1, nVertLevels uTemp(i) = 0.0 end do end subroutine do_something end module align_test_module
And here is my compile line,
$ ifort -c align_test.f90 -convert big_endian -FR -xmic-avx512 -fimf-use-svml -qopt-report-phase=vec -qopt-report=5 -align array64byte
And here is the optrpt output,
Intel(R) Advisor can now assist with vectorization and show optimization report messages with your source code. See "https://software.intel.com/en-us/intel-advisor-xe" for details. Intel(R) Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 18.0.1.163 Build 20171018 Compiler options: -c -convert big_endian -FR -xmic-avx512 -fimf-use-svml -qopt-report-phase=vec -qopt-report=5 -align array64byte Begin optimization report for: ALIGN_TEST_MODULE::DO_SOMETHING Report from: Vector optimizations [vec] LOOP BEGIN at align_test.f90(17,5) remark #15542: loop was not vectorized: inner loop was already vectorized LOOP BEGIN at align_test.f90(18,7) remark #15542: loop was not vectorized: inner loop was already vectorized LOOP BEGIN at align_test.f90(18,7) remark #15389: vectorization support: reference UTEMP(:) has unaligned access remark #15381: vectorization support: unaligned access used inside loop body remark #15305: vectorization support: vector length 16 remark #15309: vectorization support: normalized vectorization overhead 0.600 remark #15300: LOOP WAS VECTORIZED remark #15451: unmasked unaligned unit stride stores: 1 remark #15475: --- begin vector cost summary --- remark #15476: scalar cost: 3 remark #15477: vector cost: 0.310 remark #15478: estimated potential speedup: 4.000 remark #15488: --- end vector cost summary --- LOOP END LOOP BEGIN at align_test.f90(18,7) <Remainder loop for vectorization> remark #15389: vectorization support: reference UTEMP(:) has unaligned access remark #15381: vectorization support: unaligned access used inside loop body remark #15305: vectorization support: vector length 8 remark #15309: vectorization support: normalized vectorization overhead 1.250 remark #15301: REMAINDER LOOP WAS VECTORIZED LOOP END LOOP END LOOP END ===========================================================================
Now if I remove the -xmic-avx512 flag then the "unaligned access" message goes away but then I know longer have a binary that is optimized for the KNL.
Topic Options
