The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
yet another bug(??) in parameterized derived type
may_ka
Hi all
when running this code:
Module testmod
  Private
  Type, Public, abstract :: myroot(k)
    Integer, kind :: k
  End type myroot
  Type, Public, extends(myroot), abstract :: myvec
    Integer(kind=8) :: lb1=1,ub1
  End type myvec
  Type, Public, extends(myvec) :: myvec_int
    Integer(k), allocatable :: val(:,:)
  contains
    Procedure, Pass :: suba
  End type myvec_int
  Interface
    Module Subroutine suba(this)
      class(myvec_int(8)), Intent(inout) ::  this
    end Subroutine suba
  end Interface
End Module testmod
Program Test
  use testmod
  Implicit none
  Type(myvec_int(8)), allocatable :: a
  allocate(a)
  write(*,*) a%lb1
End Program Test
the parameterized derviced type (lb1 in myvec) looses its default initialization. a%lb1 is written out with zero. This does not happen if no procedure is bound to myvec_int. From my understanding this is a bug in 17.07 and 18.03.
cheers
Juergen_R_R
Valued Contributor I
I think the program is not standard compliant. Why do you try this as an interface for a module procedure? Besides this syntax in line 14/15 does not even look conform. If I change this to
contains
 ! Interface
 !Module
  Subroutine suba (this)
  end Subroutine suba
  !end Interface
then ifort gets the expected result 1. Only then nagfor compiles the code at all and delivers 1. gfortran chokes on this.
FortranFan
@may.ka,
It's a bug in Intel Fortran compiler and it is present in the compiler 19.0 Beta version as well.  You may submit a support request at the Intel OSC.
By the way, the bug appears related to the use of the MODULE SUBROUTINE for the binding to the type myvec_int.  And some may get confused by the missing implementation for it in your original post.  Though it shouldn't and doesn't make a difference with Intel Fortran and its behavior, a clearer reproducer may help:
module testmod
   private
   type, public, abstract :: myroot(k)
      integer, kind :: k
   end type myroot
   type, public, extends(myroot), abstract :: myvec
      integer(kind=8) :: lb1=1, ub1
   end type myvec
   type, public, extends(myvec) :: myvec_int
      integer(k), allocatable :: val(:,:)
   contains
      procedure, pass :: suba
   end type myvec_int
   interface
      module subroutine suba(this)
         class(myvec_int(8)), intent(inout) ::  this
      end subroutine suba
   end interface
end module testmod
submodule(testmod) sm
contains
      this%val = 0 ! an arbitrary instruction
   end subroutine suba
end submodule
program Test
   use testmod
   implicit none
   type(myvec_int(8)), allocatable :: a
   allocate(a)
   write(*,*) a%lb1
end program Test
Juergen_R_R
Ok, right, that is part of an implementation in terms of submodules. That explains why nagfor considers this to be a syntax error.
