Intel® Gaudi® AI Accelerator
Support for the Intel® Gaudi® AI Accelerator
25 Discussions
Gaudi2 - Devices 1 & 3 Showing N/A Status in hl-smi and Unusable
RajashekarK_Intel
We're currently working with a Gaudi2 machine(8 Gaudi® 2 HL-225H mezzanine cards with 3rd Gen Xeon® processors) and have encountered a problem with device recognition. When I use the hl-smi tool to check the status of the devices, I'm seeing an "N/A" status for devices 1 and 3.
Is this expected behavior under certain conditions? If not, could anyone provide insights into what might be causing this and how to resolve it?
Any help would be greatly appreciated!
Labels (2)
RajashekarK_Intel
Update here, Unfortunately after reboot.
Only 4 cards are visible and
sudo hl-smi
is also giving the same output.
RajashekarK_Intel
We've tried
Remove and load the kenel module again, but issue still persists!
rmmod habanalabs
modprobe habanalabs
James_Edwards
Can you try resetting one of the devices using the hl-smi command? The reset command needs the -i option to specify the device:
hl-smi -r -i 0000:cc:00.0
This should reset device 0. Please post the dmesg output after executing the reset.
James_Edwards
I misspoke, this command will reset device 1 (one of the problem devices):
This command will reset device 3:
hl-smi -r -i 0000:cd:00.0
Please send the dmesg output after the reset command has completed for both.
RajashekarK_Intel
Thanks for you reply, will keep these noted.
We've moved to a different instance, Thank you!
James_Edwards
Can we close this issue?
