Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
İntel Gpa blocked
medd
When I manually launch my application CS2, it is blocked by faceit. When I turn off Faceit, it works fine. How can I run GPA manually when Faceit is open?
sentientSpark_Intel
Hi medd,
As you noticed, some Anti Cheat services such as the ones FACEIT may use prevent Intel GPA from injection into Counter Strike 2. Streams and Frames can be captured using Counter-Strike 2 by itself for your graphics analysis purposes. You would need to contact the FACEIT team for an unprotected version in order to use Counter-Strike 2 with FACEIT with GPA.
