Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
Error opening captured frame from project made with UE4 + DX12
Luchetta__Fabio
I made a simple project with UE4 (version 4.20.3), to check if it's possible to capture a frame using DX12 with the last version of GPA (18.3).
The capture worked (ctrl-shift-C) and I see a file saved with the .gpa_frame extension in the Docs/GPA folder.
But if I try to open it with the Frame Analyzer I get this error:
"An internal error occured. Graphics Frame Analyzer may fail to work correctly. Reopen the frame to fix the issue.".
I tried more times to reopen the frame, but without success.
Is there anything I can do? I'm using a PC with a GeForce 1080 ti and the latest nvidia drivers (416.34).
Fabio
Giselle_G_Intel
Hi Fabio,
Could you send me a private message with the frame attached to share with our engineering team? It'll help us identify the underlying issue.
Also, could you send the about info found under icon.png  button in Graphics Monitor?
Luchetta__Fabio
Hi Giselle,
thanks for your reply! See attached info file from the Graphics Monitor.
How can I send you the frame? Zipped is about 24 MB.
Fabio
