Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
533 Discussions
GPA 4.0: crash occurs when GPA tries to attach to my game
Praveen1
I installed latest GPA on my Dell laptop. But the application selection screen is not working (neither can launch new nor can detect). It gives exception error. Attached is the complete error report and my system configuration.
Pls help us in getting this fixed.
Laptop Conf:
Dell Inspiron N4010
Intel Corei3 CPU M370 @2.40GHZ 2,40 GHZ
3 GB (2.86 GB usable)
64-bit Windows 7 Home Basic
Error:
InvalidArgument=Value of '0' is not valid for 'index'
Detail:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: InvalidArgument=Value of '0' is not valid for 'index'.
Parameter name: index
at System.Windows.Forms.ListView.SelectedListViewItemCollection.get_Item(Int32 index)
at GPAMonitorGUI.OpenDlg.CreateEditProfile()
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
gpamonitor
Assembly Version: 1.0.0.0
Win32 Version: 4, 0, 2, 13165
CodeBase: file:///C:/Program%20Files/Intel/GPA%20v4.0/gpamonitor.exe
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
gpautils2
Assembly Version: 1.0.4134.40436
CodeBase: file:///C:/Program%20Files/Intel/GPA%20v4.0/gpautils2.DLL
msvcm90
Assembly Version: 9.0.30729.4926
Win32 Version: 9.00.30729.4926
CodeBase: file:///C:/Windows/WinSxS/amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4926_none_08e1a05ba83fe554/msvcm90.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Neal_Pierman
Valued Contributor I
Sorry that you're running into problems with Intel GPA.
To help track down the problem:
  1. Would you be able to include the output from GPA Monitor's "About..." screen (right-click on the GPA Monitor icon to see this option)? This will give us more information about your specific configuration.
  2. Does the problem occur when attaching to any game/application (including the GPA sample), or only a particular game?
  3. Do you have any anti-virus software installed?
Thanks!
Neal
Neal_Pierman
I've not heard any response back from you, but I wanted to check on the status of this issue. Is this still a problem for you, or have you been able to resolve it on your own?
The reason I'm asking is that I've seen issues such as yours when an anti-virus program is running. Another customer mentioned a similar problem, so I'm wondering if you are running Symantec Endpoint Protection? Please let me know more details and I'll try working with the GPA Development Team to help resolve this issue.
Thanks in advance for your response.
Neal
Neal_Pierman
Hello again,
Here is another suggestion for you... please try removing MonitorConfig.xml from the GPA 4.0 directory in your user area, then rerun GPA Monitor. Also please check the permissions on this file to see if it is accessible by at least the user/game you are testing.
If this still does not work, then also include a copy of the MonitorConfig.xml file for us to examine.
Thanks!
Neal
