Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
550 Discussions
Intel® Graphics Performance Analyzers 2023.1 Release is Out!
Pamela_H_Intel
Hello All,
The Intel® Graphics Performance Analyzers team is proud to announce Intel® GPA 2023.1!
You can download Intel® GPA 2023.1 for FREE from the Intel® GPA homepage.
Watch the full release video from the GPA website, or on Intel's YouTube channel.
Graphics Frame Analyzer
  • Added pipeline statistics and performance metrics for mesh shaders, amplification shaders, and task shaders.
  • Updated Dependency Viewer documentation (formerly called Render Target Dependency Viewer).
System Analyzer
  • Added support for CPU metrics for 12th and 13th gen Intel® Core™ processors (formerly code named Alder Lake and Raptor Lake) for comparing workloads across Performance-cores and Efficient-cores.
Intel® GPA Framework
  • Added a capture layer compression option. This can reduce the captured stream size by up to 30%, reducing storage needs over time if streams are stored for tasks such as regression testing.
  • Improved the stability and support of a broader range of DirectX* Raytracing (DXR) workloads in the framework subcapture recorder tool.
  • Added a dump-render-targets layer that can allow users to write out render targets to a file.
  • Added support for Vulkan* SDK version 1.3.239.0.
Note: Qt source code is available here: https://archive.softwareheritage.org/ SWHID is swh:1:rev:12782df8963d39f7ebaee6979567c7c1b8bb8c11
PreyK
The download link seems to be broken.
When I click download for windows, it redirects me to a page not found.
When I right-click to save as chrome says "download failed - denied"
Pamela_H_Intel
Thanks for letting us know. Sadly, the download system migration didn't go as smoothly as expected. It should be good now.
remotedev
Graphics Monitor and other tools can't run on Windows 11 with video card NVidia RTX 3070 Laptop version without reporting any error message boxes.
How to check logs?
P.S. Runs and works only Intel Graphics Command Center.
Thanks!
Pamela_H_Intel
I think you asking a Graphics question? - https://community.intel.com/t5/Graphics/bd-p/graphics - please post in this other forum
remotedev
Only after installing the latest version of the driver for Intel ARC tools worked.
